what is a good 12v constant to tap into for my IAB's
i need to know a good wire to tap into for my 12v constant to activate my IAB's. i was thinking one of my o2 sensor wires but not sure which wire. anyone else got suggestions please tell in great deatil the color of the wire and location thanks
Seagull Management
Re: what is a good 12v constant to tap into for my IAB's
If it's OBD1 and you don't have strict emissions testing simply unplug the evap purge connector from the evap purge solenoid and plug it into the the IAB solenoid and repin A20 to A17 at the ECU.
its a obd2a motor with stock obd1 civic harness i dont think it has evap purge plug on civic harness? plus im gonna use a chipped ecu with evap deleted crank sensor deleted and knock deleted.
My B7 and Z6 had evap purge solenoids. Look again....it will probably be on the intake manifold.
http://www.ff-squad.com/tech/sensors/purgesolenoid.jpg
Seagull Management
Civic harness has an evap purge solenoid. The whole point is you're using the wiring for it to run something else so you don't have to run any new wiring. Evap purge wont throw a code even if it's not deleted.
Rease3
10
06-24-2009 05:08 PM
hatchnideas
07-14-2007 12:24 PM
