burns oil...sometimes? d16y8
just trying to see why it is that my engine burns oil intermittently. any ideas? replaced rear main and oil pan set. no leaks, just burns it. sometimes. 160k miles
Re: burns oil...sometimes? d1678
is it while accelerating at higher rpm's? like over 3k. my civic wagovan does it and i know its the rings... but still runs like a champ for 213k miles.
But wouldn't there be signs of oil in the coolant if it were the head gasket?
And no its just under normal daily driving. I try not to beat her up too bad cuz its my only car. But its very intermittent. Like it goes a cpl weeks without any loss, i check it periodically, then out of no where, its down almosst two quarts. I was thinking I might be running the wrong weight of oil and the mottor is just being tempermental. 5-30 castrol syntec ... any other ideas? Oil isn't cheap anymore lol
Re: burns oil...sometimes? d16y8
By the way, to say that the engine "suddenly" drops almost 2 quarts, you would need to check the oil level daily on level ground an hour or so after the engine has been turned off.
well turns out you guys were right....not to blow dust off this or anything. but my valve cover bolt (passenger side closest to the firewall) broke off, and was slightly leaking oil out of the valve cover gasket and the bolt grommet. fixed now, no issues any more!
brios86
12
11-29-2011 10:29 PM
blacktibby07
02-13-2011 09:50 AM
