Is 245 c/r to high to boost on Gsr motor?
Old 01-15-2011, 10:18 AM
92GSREG's Avatar
Default Is 245 c/r to high to boost on Gsr motor?
i just baught a b18c1 motor and i was planning to boost atleast 8-10 lbs , but my compression came out 245 on all 4 cylinders, is that to high to boost or should i go lower? if so whats a good low comp to go on.
Old 01-15-2011, 10:26 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Is 245 c/r to high to boost on Gsr motor?
What?
Old 01-15-2011, 10:57 AM
apexi_rsx's Avatar
compression tester does not tell ur compression ratio. a gsr is on the high side but it is possible to boost but not high boost on PUMP GAS. if u wanna run pump gas and high boost id recommend getting lower compression pistons.
Old 01-15-2011, 01:45 PM
Master Detailer
98civdx's Avatar
Those numbers dont tell us the compression ratio of the engine.
What they do tell us is you have good compression and a healthy motor. Boost away, just insure you get a good tune.
Gsr's are great engines to boost, My friend has been on 10psi ( forgot turbo size) on a all stock motor for 2 years without any issues.
The turbo size is very important!
Old 01-15-2011, 01:47 PM
93egSLEEPER's Avatar
Stock GSR's should register 240-250psi on a compression test if they are healthy. That is also what is suggesting stock CR. Go ahead and boost it, but getting it tuned is more important. Rather then saying 8-10psi what are your HP goals?
Old 01-15-2011, 04:15 PM
MonkeyMagic's Avatar
you can boost anything.
-the boost you run and the resulting combination of cylinder temperatures and pressure kill things.
-knock kills things.. caused by surpassing the available fuel's octane rating or by..
-the tuning, or lack there-of, which causes detonation (knock) or high cylinder temps and pressures, which kills things.
as for your stock gsr.. there are literally volumes of books dedicated to such a simple question. but to keep things short i'd get a competent fuel system and cooling system, a turbo system with some intelligence behind it's engineering, and some good old grade-a tuning and as long as you don't get boost happy.. i doubt you'll ever have a problem.
ivebenjamin
02-02-2006 11:34 PM
PePpeRedDc5
05-22-2005 09:36 AM
RooskiGSR
02-28-2005 04:23 PM
1SIKCRX
10-13-2003 10:04 PM
Quick Reply: Is 245 c/r to high to boost on Gsr motor?
