2000 Si electrical problems
I have a 2000 civic si and it keepsblowing my tail light fuses and it just started blowing my turn signal fuses also. I changed the fuses and i saw a bright flash underneath the dash by the pedals. Didnt know if this was a common problem or if anyone has ran into the same problem. I really need some help thanks
The Grumpiest
Re: 2000 Si electrical problems
No bright flashes from beneath your dash is not common. You have a short somewhere. You'll have to track it down. Probably where ever you saw that flash from.
Sounds like you have a bare wire either touching another bare wire or shorting out into metal. Probably in the area of the flash. Flashlight and back pain time!
i talked to a few people and they said it was the fuses blowing at the same time which caused the flash...so i will check the tailight harness that could be it
lryfall
Honda CR-V & Element
02-12-2014 06:14 AM
loosestring
02-17-2013 03:48 PM
