ticking noise from motor?
my car started making a ticking sound the other day. its a mini me swap, d15b7 block with a d16z6 head. sounds like a valve tick so i did a valve adjust on it and it didn't make a difference. one of my boys said i may have a worn cam or cam journal. i am goin to check that in the am but just wanted to get input from people to see if anyone has had the same problem.
Re: ticking noise from motor?
if a cam lobe is scored up, when you look at it you'll see it. Pull the cam and if it is, go zex or bishimoto stage 1 and you won't need a tune(= to d15b stock cam). if it's valve lash readjust your valves, but the damage could be done. in any case PULL THE HEAD and INSPECT.
i think its when the vtec heads get old they start makeing a slight ticking noise mine sounded like a small knock but the motor was like that till i sold the car
DC2-Interceptor
03-31-2005 10:32 PM
Mike banX
09-03-2004 10:11 AM
