Rock hard spark plug tube seals
The seals on underside of valve cover at top of spark plug tube. They are all hard as rock, don't want to come off. Any suggestions? I've put 65K on the car but total is 216K, these could be original.
I pretty well destroyed the #1 seal but there's still the core rubber ring bonded against the flat aluminum surface. Is there something I can soak the cover in that will dissolve the hardened rubber?
H-T White Ops
Re: Rock hard spark plug tube seals
Flatheads can damage the valve cover in my experience. I use needlenose pliers, grab the seal and twist.
There's a metal coil inside the seal. Don't worry about damaging that. It's just part of the seal and is inside the replacement seal as well.
Grab ring from going down from above? (OK, the whole valve cover is upside down but you know what I mean.) At the notch in the valve cover?
A local friend said to hit edgewise on the ring using screwdriver blade or chisel, with hammer. To make the circle cave in. The rubber ring has the coil spring inside but also has a metal ring embedded.
H-T White Ops
Not to be obtuse, but...
We remove the seals every time we paint a valve cover here.
Crazy Honda Guy
i've used pliers or needle nose myself on the tough ones, trust me, they will come out. As with anything, take care in not damaging the underside of the cover, it's not too hard
Ritchie
12
12-21-2006 07:29 PM
powerslide360
04-26-2006 12:51 AM
mntdewred
06-03-2005 02:23 PM
VTECMaster
11-22-2004 06:47 AM
