What are my OEM radiator optios in my EJ?
Old Feb 22, 2004 | 10:27 PM
Go-Cart's Avatar
Default What are my OEM radiator options in my EJ?
My radiator has a leak so I wanted to upgrade since I'm already spending some cash. Can a duel core fit, and what mods are needed to mount it?
Modified by Go-Cart at 1:41 AM 2/23/2004
Modified by Go-Cart at 8:42 AM 2/24/2004
Old Feb 23, 2004 | 09:59 AM
Go-Cart's Avatar
Default Re: What are my OEM radiator options in my EJ? (Go-Cart)
Anyone??
Old Feb 23, 2004 | 10:05 AM
JasonBlackEJ1's Avatar
get a del sol one
Old Feb 23, 2004 | 10:31 AM
Go-Cart's Avatar
Default Re: What are my OEM radiator options in my EJ? (JasonBlackEJ1)
Is it a direct bolt on or do I need to mod the support.
Old Feb 24, 2004 | 05:39 AM
Go-Cart's Avatar
bump for more info please!!
Old Feb 24, 2004 | 08:18 AM
dsadas89das78934's Avatar
just get a radiator for either a del sol or an auto civic, they are dual core radiators... also check ebay for "dual core radiator" , i picked up a NIB radiator for $80 shipped
Old Feb 24, 2004 | 09:46 PM
Go-Cart's Avatar
Default Re: (soccaian)
So a dual core fits in the same space and in the same way as my stock radiator?
Old Feb 25, 2004 | 07:22 AM
Go-Cart's Avatar
Default Re: (Go-Cart)
Bump??
Old Feb 25, 2004 | 07:31 AM
ih8danoles's Avatar
I need to know this also.. Will a del sol fit without modification? I looked at a few aftermarket ones on ebay but they looked too wide to fit where the stock radiator is without mod.
Old Feb 25, 2004 | 07:59 PM
Go-Cart's Avatar
Default Re: (ih8danoles)
Bump. I know someone knows this one.
Old Feb 25, 2004 | 08:06 PM
RTE117's Avatar
I'm using a GSR one in my 97. One of the lower brackets (or both I can't remember) had to be moved to use it. Two holes had to be drilled into my core support and homemade braces made.
Old Feb 25, 2004 | 08:08 PM
Go-Cart's Avatar
Default Re: What are my OEM radiator options in my EJ? (IDriveAHonda)
Anyone know about a Del sol dual core in a 94 EJ? What mods are needed?
Old Feb 25, 2004 | 08:11 PM
Skip01's Avatar
You can get a stock one from autozone and they are dual core.Or you might have to ask for dual core.Direct bolt-on.
AmginE's Avatar
just get a dual core del sol.
Oreilly sells an ALUMINUM (ooh bling) Dual core del sol one for 100.
Old Feb 25, 2004 | 08:49 PM
Sector9guy's Avatar
Default Re: What are my OEM radiator options in my EJ? (AmginE)
no one seems to be answering your question, so yes, a del sol one is a direct fit. upgraded my cracked single core to dual core, diggin it so far.
Old Feb 25, 2004 | 08:52 PM
Echo7847's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Go-Cart &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know about a Del sol dual core in a 94 EJ? What mods are needed?</TD></TR></TABLE>Direct fit no modding necessary. I have one
Old Feb 25, 2004 | 09:29 PM
Go-Cart's Avatar
Default Re: What are my OEM radiator options in my EJ? (sector9guy)
Thanks!!
Old Feb 25, 2004 | 10:29 PM
Street Ghost's Avatar
If it helps, I have a dual core in my 93 Civic.
Old Feb 25, 2004 | 10:36 PM
AmginE's Avatar
Default Re: What are my OEM radiator options in my EJ? (93 EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">If it helps, I have a dual core in my 93 Civic.</TD></TR></TABLE>
me too
Old Feb 26, 2004 | 07:27 AM
ih8danoles's Avatar
are all the del sol model radiators the same? Should i specify the B16 VTEC? or do i need the one from the model with the Z6?
Old Feb 26, 2004 | 07:44 AM
ace1875's Avatar
Default Re: What are my OEM radiator options in my EJ? (ih8danoles)
eBay has dual core for $76 with free shipping and lifetime warranty.
and yes any civic from 92-95 will fit a dual core from a delsol without any mods
Old Feb 26, 2004 | 08:31 AM
Turbo E's Avatar
FYI i Have a turboed GSR swap in my EJ and i never overheat at all. (OEM rad)
louevilhatch
Nov 7, 2007 04:29 AM
MugenT
Jun 3, 2005 03:23 PM
95GSRTT
Apr 18, 2005 07:18 PM
95GSRTT
Apr 18, 2005 03:11 PM
jdmCivic925
Jul 13, 2004 04:27 PM
