removing dashboard in a ek?
im planning on removing my dashboard in my ek tomorrow, can someone that has done it before in a ek tell me where all the bolts are? thanks in advance.
beleive its a pain in the **** ta do, guessin its ta fit ya clock ? some peeps have said its just easier to remove the stereo and fit that way. little tricky though
https://honda-tech.com/zerothread?id=605432
this should help you locate the bolts and see what is all behind the dash...
its not for the clock, i had that installed in 10 minutes. for that i pulled off the climate control. im actually going to change the dash harness b/c the guy i bought the car off of chopped it up the wiring behind the cluster pretty bad. everything works fine but the picture off but connecters still lingers in my mind. that was a great how to on the climate control conversion. thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankdatank »</TD></TR><TR><TD CLASS="quote">that was a great how to on the climate control conversion. thanks again</TD></TR></TABLE>
yeah it really is a great how to. No problem I hope it has everything you need, taking out dash doesn't seem that hard puttin it back in without it making noise all the time is gonna be the hardest part.
import-tooner
Dec 11, 2009 02:31 PM
