Headlights won't turn on
Old Feb 23, 2004 | 05:21 PM
hawjboi's Avatar
Default Help: Headlights won't turn on
Alright i live in michigan and its cold usually. So my lights won't turn on rite away when i flip the switch. It takes a minute or up to 5 min. to turn on. anyone know what i can do to fix this problem cause i hate waiting for my light to turn on at night. In the summer i have no problem...help?
Modified by hawjboi at 2:32 AM 2/24/2004
Modified by hawjboi at 2:33 AM 2/24/2004
Old Feb 23, 2004 | 05:33 PM
hawjboi's Avatar
Default Re: Help: Headlights won't turn on (hawjboi)
anyone
Old Feb 23, 2004 | 05:46 PM
JimmyAtlantis's Avatar
I have the exact same problem (94 coupe). It was cold (-20F) here also for a few weeks over the winter, but I've never had to wait that 5 minutes. I don't think I've even had to wait 30 seconds. Bump - I'm curious also.
Old Feb 23, 2004 | 07:17 PM
hawjboi's Avatar
Default Re: Help: Headlights won't turn on (JRI94)
bump
Old Feb 24, 2004 | 03:35 AM
bump again
Old Feb 24, 2004 | 01:28 PM
hawjboi's Avatar
anyone have the same problem?
Old Feb 24, 2004 | 01:32 PM
Formula 1's Avatar
grounds? wires checked?
Old Feb 24, 2004 | 01:50 PM
screech's Avatar
thats some killer hid warm up time
jk free bump for you
Old Feb 24, 2004 | 01:58 PM
Formula 1's Avatar
Default Re: Help: Headlights won't turn on (screech)
also check battery voltage before car is started with leads on and off
Old Feb 24, 2004 | 02:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screech &raquo;</TD></TR><TR><TD CLASS="quote">thats some killer hid warm up time
jk free bump for you</TD></TR></TABLE>
I actually don't even want HIDs. I can see just fine with my SilverStars. It's all in proper alignment.
Yes, grounds are brand new. Wires are fine. It's only when it's super cold (below 15F).
Old Feb 24, 2004 | 02:16 PM
Formula 1's Avatar
Default Re: Help: Headlights won't turn on (SikCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic &raquo;</TD></TR><TR><TD CLASS="quote">also check battery voltage before car is started with leads on and off</TD></TR></TABLE>
checked?
Old Feb 25, 2004 | 03:49 AM
^^^No, but the alternator is freshly rebuilt and the battery is brand new. I have plenty of juice.
Old Feb 25, 2004 | 06:44 PM
hawjboi's Avatar
anyone...still having a problem with them...ground and everthing is fine...
Old Feb 26, 2004 | 01:09 AM
Formula 1's Avatar
Default Re: (hawjboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawjboi &raquo;</TD></TR><TR><TD CLASS="quote">anyone...still having a problem with them...ground and everthing is fine...</TD></TR></TABLE>
so yours stopped?
Old Feb 26, 2004 | 03:27 AM
Default Re: (SikCivic)
Mine stopped once the temperature got out of the negatives. I won't see this issue again until next winter. *knockin' on wood*
Old Feb 26, 2004 | 04:52 AM
ironcheftony's Avatar
flick the high beams on and off and turn the driving lights on and off then it should work
Old Feb 26, 2004 | 05:47 AM
upgraded's Avatar
I had this same problem. My headlights would not come on when I turned on the switch but if I wiggled the switch they would come on but sometimes would flicker dim while driving. After a few weeks the combo switch burnt up while I was driving home. I replaced it and all is good. this was on a 92 si. hope this helps.
Old Feb 26, 2004 | 06:18 AM
Default Re: (upgraded)
Well how much does that combo switch thingy cost and what's the part number? I guess I may have to give that a try if it still acts up next winter. I don't think it will get cold enough for it to happen again.
Old Feb 26, 2004 | 08:42 AM
hawjboi's Avatar
ALl my headlights work...just that it hesitates to turn on when i need it the most...expecially in the winter time...it takes forever to turn on...dont know what the problem could be though...even if i turn on and off the high beam it still takes time for the lights to turn on...any suggestion...
Will Gabriel
Honda Civic (2001 - 2005)
Aug 21, 2014 11:51 AM
ludesrv
May 4, 2007 10:30 PM
87turdR
Nov 23, 2005 01:11 PM
SeaBass
Jul 1, 2003 06:10 PM
