Fuel Filter problem
I have a 95 sol, and I tryed to remove the lower fuel line from the fuel filter and striped the fitting. The fitting/nut is still on, and have been driving like that for a long time, but I just want to have a new fuel filter on soon.
Now here are my options
1. Keep it on there, just live with the old fuel filter (probally 150k miles old
2. With a pair of vice grips, remove the nut/fitting, and hope I can get it back on with the vice grips
3. Remove with vice grips, then replace the hole line.
3 In my mind seams like a winner, however, how long is that fuel line, and where does it go to? Has anyone ever had this problem before?
)2. With a pair of vice grips, remove the nut/fitting, and hope I can get it back on with the vice grips
the bottom line goes all the way to your fuel tank, so replacing it will be time consuming, but you can replace it with stainless steel line.
http://www.fast-turbo.com has a kit for your car, the guys name is stan, he's a sponsor ont he board.
make sure you are looking at the correct fuel line for your car and not the fuel line from the fuel filter to the fuel rail. I can't imagine that fuel line that goes from the front of the car to the rear being that cheap.
I am looking at the right part. It is just a Steel tube with a fitting that is premolded for the car. Not super hard to manufactor. True the SS line costs 300 or so, but the line from Hondaautomotiveparts.com is only 50 or so.
2-7offsuit
May 25, 2006 01:38 PM
moonpieboy
Oct 9, 2005 09:57 AM
next time use flare wrenches and hose it down in penetraiting oil for like 2 days prior
