how hard to change pistons!!!!!!quick!
this guy has my head apart he says its a lot of labor to change pistons how hard is it he says its gunna cost a lot of cash is this true or is it simple if the engine is already dropped n the head is already off based on 1- 10 10 bein the hardest how hard would u consider it ????? quick thankszz
you have to disassemble the block, separate the pistons from the rods, then press the wrist pins into the new pistons and rods, then you have to check clearances, space the rings, etc...its very time consuming, and labor = time x money
yea...it's pretty hard, but if u want it done, u gotta pay the $$$ or else do it yourself.... assuming ur mechanically inclined. But that ish is time consuming...and i mean time consuming
If its your first time doing this then it would probably take you about a week or 2 to get it right. If you got the skills it could be done in 2 days. If not 2 weeks.
