ECU is HUMMING
I have a p28 running a y8 in a 89 Hatch Si
The ECU hummms at a certain throttle point, regardless of gear, speed etc.
I had a different ECU prior on the same setup, and it did not do this, but when I put in the stock p28 instead of a pgmfi.org chipped ECU it started humming,
Ideas?
Ideas?
I've check and rechecked,
even regrounded my entire engine, block, head, tranny, intake mani, all with 2 gauge and back to the common battery ground.
Still no help,
So you thinking ECU then?
Still no help,
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by groundedcivic91 »</TD></TR><TR><TD CLASS="quote">I've check and rechecked,
Still no help,
So you thinking ECU then?</TD></TR></TABLE>
You did all this before finding another ECU and trying it out? Mad props on your enthusiasm
Still no help,
Hybrid-Fusion
15
May 8, 2007 10:46 AM
