Belt Tension - what is too tight??
Hi, I just recently changed my alt/PS/AC belts,
How hard do I push on the belt to measure the deflection listed in the Helms?? I'm afraid I will make them too tight. Right now they make noise (too loose), but I thought I made them pretty tight. Maybe it's just the alt belt... that one was hard to get tight.
Thanks
Thanks
use a pry bar and lean on it quite a bit ......you'll know when you get it tight enough it's not hard!
i used a crowbar and it was quite simple!
i couldn't really tell you exactly .......tho it should say in a helms/haynes manual, or just give your local Honda dealer a shout, they'll tell ya for sure!
well if it says to push at 22 lbs....thats not a whole lot ......i would just suggest pushing on it about as hard as you would tighten a bolt with a rachet.....about a good push....if that makes any sense at all to you!
superthug
Aug 2, 2008 08:02 PM
igo4bmx
Jul 5, 2005 08:29 PM
