Trying to install power windows......
Old Feb 23, 2004 | 08:22 PM
K20_Rey's Avatar
Default Trying to install power windows......
I have been reading and searching, and everybody has been saying that coupe EG stuff bolts right up to hatchback EG's. Well, the window regulator doesn't seem to bolt up right. Below is a pic of what I am talkign about. The manual bolts line up to make a rectangel shape, and the electric ones line up to make a pyramid shaped quadrilateral. Any help would be much appreciated.
Old Feb 23, 2004 | 08:25 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Trying to install power windows...... (K20_Rey)
Have you checked out this site yet?
Here:
http://repo.jackmoves.com/view...bun42
I wish I could be of more help, but I won't be doing this swap for another two weeks.
Filliam H. Muffman's Avatar
you see those other holes?
use them.
and are you sure you're putting it in right?
EDIT:
nice link
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INVALID &raquo;</TD></TR><TR><TD CLASS="quote">Have you checked out this site yet?
Here:
I wish I could be of more help, but I won't be doing this swap for another two weeks. </TD></TR></TABLE>
Old Feb 23, 2004 | 08:28 PM
K20_Rey's Avatar
Yah, been to that site. That's where I got some of my pics. I tried for almost 2 hours to line that **** up, and can't get more than 2 at a time.
Old Feb 23, 2004 | 08:29 PM
ieatrice's Avatar
bump! i'd like to know also 'cuz i want PW in my hatchizzle.
Old Feb 23, 2004 | 08:36 PM
Shawn C's Avatar
In The Garage
you sure you're puttin the right regulator in the right door? they should line up fine. you might have to move the arms a bit, but they will line up fine.
Old Feb 23, 2004 | 08:39 PM
INVALID's Avatar
Default Re: (K20_Rey)
Are you bolting in the left two first, I looked at a few pictures, there isn't a difference in bolt pattern so it's just the way it aligns. Is the window crank still in the way? I would attempt to bolt in keeping everything somewhat loose then tightening everything down. I know there isn't anything I can tell you that you haven't attempted with two hours of clocked time, but not physically being able to see this is difficult.
Old Feb 23, 2004 | 08:44 PM
G U E C O's Avatar
Default Re: (INVALID)
they should be the same
Old Feb 23, 2004 | 09:03 PM
K20_Rey's Avatar
I will try the left 2 bolts first, then work from there tomorrow. Sheesh this is a bitch. Keep the info comming guys.
Old Feb 23, 2004 | 09:08 PM
INVALID's Avatar
I'm tired...I meant the right two cause those you will be able to move up and down until you tighten, opposed to the left side just setting there once the bolts are placed in.
Old Feb 23, 2004 | 09:14 PM
Cheivic's Avatar
Yes they fit. You only use 2 of the original holes (if i'm remembering correctly). The other 2 are like right above and right below the other 2 holes.
See the other hole on the bottom right? One bolt goes in there. I don't remember but I think there's another one just like it in the top right where the bolt bolts up to.
Old Feb 23, 2004 | 09:26 PM
K20_Rey's Avatar
Thanks to all who posted. If I can get a digicam, I will post pics.
Old Feb 24, 2004 | 06:53 PM
K20_Rey's Avatar
Anybody know where I can get one of these relays? I checked planet honda and they weren't on their site. It has to be on that Majestic Honda parts site, but I have no idea what relay it is.
Old Feb 24, 2004 | 07:36 PM
Cheivic's Avatar
http://www.hondaautomotivepart...0-003
Old Feb 24, 2004 | 07:38 PM
K20_Rey's Avatar
Thanks a bunch!! I really needed that part :D
Old Feb 24, 2004 | 07:51 PM
eg crunkmonster's Avatar
everything bolts right up....i have PW in my hatch and the windows came out of a 92 civic ex and my car is a 95 CX (not that the years matter)
Old Feb 24, 2004 | 08:08 PM
xerox445's Avatar
Default Re: (eg cookiemonster)
question, i have an integra dash harness in my car...and i have those plugs for the PW onthe ground, do they match up with a ex door? Could i use ex doors with my integra plug?
Old Feb 24, 2004 | 08:11 PM
K20_Rey's Avatar
You could try. It all depends if they connectors actually fit together. But, you can always cut the harnesses and splice the wires. As long they are all going to the right place.....
Old Feb 24, 2004 | 08:12 PM
xerox445's Avatar
yeah, also where are the relays for the PW located? under the hood ?
Old Feb 24, 2004 | 08:13 PM
K20_Rey's Avatar
under the dash by the fuse box
Old Feb 24, 2004 | 08:15 PM
xerox445's Avatar
kool, i have the teg fuse box...does it plug into the box?
Old Feb 24, 2004 | 08:18 PM
K20_Rey's Avatar
I have no idea. You can go to a junk yard and find a POS civic and get the relay from that one and try it out. Just pocket the relay, nobody will miss it.......
Or just buy it LOL
Old Feb 24, 2004 | 08:20 PM
xerox445's Avatar
five finger discount y0!
Wait, am i going 2 get banned for being a theif...
Yeah, sounds good. This makes things alot easyer...no wiring nessary....
BTW, anyone have power doors or the regulator setup for sale cheap?
Old Feb 24, 2004 | 08:23 PM
drunknbass's Avatar
to make it easier start the bolt in the regulator and then youll see the holes it goes in are like the shape of a pendulum, thats so you can put the regulator on with the screws already started so you dont have to break your wrist trying to hold everything lined up inside the door.
Old Feb 24, 2004 | 08:28 PM
K20_Rey's Avatar
Cool, thanks for the advice.
You might want to try DAP or HAP, they both sell used honda parts for decent prices.
http://cgi6.ebay.com/ebaymotor...ws=50
http://www.haprecyc.com/
