I need the plug that the VX 5 wire O2 plugs into. Anyone have one?
Old Feb 23, 2004 | 07:41 AM
Bailhatch's Avatar
Default I need the plug that the VX 5 wire O2 plugs into. Anyone have one?
Hi, already checked this post with the moderator, I need the plug from the wiring harness side of the VX O2 sensor. The one the O2 plugs into. Hopefully someone has done a 5 to 4 wire conversion and kept your old plug. I will paypal you $15 if you can ship me yours. It needs to have at least 1/2" of wires left to solder to. Thanks for your help guys!
Old Feb 23, 2004 | 10:58 AM
Bailhatch's Avatar
Default Re: I need the plug that the VX 5 wire O2 plugs into. Anyone have one? (Bailhatch)
you right there! you have one right?
Old Feb 25, 2004 | 02:27 PM
streetstylenperformance's Avatar
I am trying to figure out which wires splice to what and then you can have mine. 98 hx do you have the pin out becasue mine has 7 wires leading to the five wire o2.
Old Feb 25, 2004 | 03:37 PM
96dc2's Avatar
Default Re: I need the plug that the VX 5 wire O2 plugs into. Anyone have one? (streetstylenperformance)
There are these connectors in my 96 Integra GS-R. Just giving you an alternative in case you can't find ones from VX's.
This one located by the clutch master cylinder as you can see.
This one located on the left side of the radiator/fan, right next to the coolant resevoir.
Old Feb 26, 2004 | 12:02 PM
Bailhatch's Avatar
Default Re: I need the plug that the VX 5 wire O2 plugs into. Anyone have one? (96dc2)
No I don't have the pinout for this plug. Yup should have 7 pins in an 8 spot plug.
I haven't tried any other plugs from a honda yet. I'll see if any fit. Thanks for the idea 96dc2
AllMotorNoPower
May 1, 2017 10:39 PM
Mfoehrkolb
23
Oct 17, 2011 12:21 PM
redej878
Apr 20, 2006 08:27 AM
92b16vx
May 22, 2003 02:45 PM
splitime
Sep 7, 2002 07:27 PM
