ITR Intake Mnifold and TB install...
Old Feb 22, 2004 | 05:01 PM
blu2ksi's Avatar
Default ITR Intake Mnifold and TB install...
B16a2 ,im installing a type r intake manifold and TB, any difficulties, tightening patterns? any info will help...
Old Feb 22, 2004 | 05:03 PM
Ricey McRicerton's Avatar
Default Re: ITR Intake Mnifold and TB install... (blu2ksi)
Pretty much just a direct swap. Grab your helms for the bolt tigtening pattern and go for it. I always tighten from the inside out (from the middle of the car twoards the sides).
Old Feb 22, 2004 | 06:37 PM
2000CX's Avatar
Default Re: ITR Intake Mnifold and TB install... (Ricey McRicerton)
not to jack or anything...but is an itr throttle body a direct swap onto an 00 b16? are all the same sensors already on it and will the stock throttle cable still work? thanks in advance for any help!
Old Feb 22, 2004 | 06:38 PM
Default Re: ITR Intake Mnifold and TB install... (2000CX)
I'm almost 100% positive it is. But you would need to portmatch the intake mani to the TB for it to be effective.
Old Feb 22, 2004 | 06:47 PM
2000CX's Avatar
sorry man...that post was kinda confusing. i meant to install the itr throttle body WITH the itr intake manifold...thanks for the answer though
Old Feb 22, 2004 | 06:49 PM
99blackcivicSi's Avatar
skunk2 is the same as a itr, installed mine just like factory and bolted a STR 68mm up to it and it worked fine iwht my stock throttle cable bracket and cable
wasanissanFL
Mar 12, 2015 09:35 PM
Daniel-sanB1
Jun 7, 2007 01:21 PM
Daniel-sanB1
Jun 6, 2007 10:10 PM
Orangecivic251
Jun 9, 2004 10:30 PM
