need help w/ piston Question SOHC
Old Feb 23, 2004 | 08:25 PM
kiddcheng's Avatar
Default need help w/ piston Question SOHC
https://honda-tech.com/zerothread?id=765221
this is the thread, all the spec is there....
k, i'm in the process of buying these piston from a fellow HT member *already bought acutally*. WELL, the part number he listed was different, says it was for a d16a6. Can i still use it in my d16z6 motor? It says for nitrous set up though....cuzz i'm going to be going turbo and just wondering if these will do the job. What will my comp/ratio be??? ............If you guys can help me asap...before i put it in the wrong motor...thanks!
Old Feb 23, 2004 | 08:27 PM
kiddcheng's Avatar
Default Re: need help w/ piston Question SOHC (kiddcheng)
help
Old Feb 23, 2004 | 08:29 PM
kiddcheng's Avatar
help
kiddcheng's Avatar
bump...help
Old Feb 23, 2004 | 08:36 PM
skip.two's Avatar
your CR will be too high for turbo w/ those pistons.
Modified by jL iLLuZiOnz 9 at 9:58 PM 2/23/2004
Old Feb 23, 2004 | 08:38 PM
Shawn C's Avatar
In The Garage
it will give you high compression. don't use those pistons if you intend on turbocharging the engine. if you are going all-motor, then they will be great
read- too high of a CR for turbo
Old Feb 24, 2004 | 10:01 PM
PornstaR16L's Avatar
like i said before just read the stats for the pistons. Aint gonna work thats why I didnt buy them.
Old Feb 24, 2004 | 10:36 PM
kiddcheng's Avatar
Default Re: need help w/ piston Question SOHC (PornstaR16L)
PLEASE DELETE...thanks MONIRATOR
KamikazeDR
Jun 12, 2011 08:48 PM
W O T
Jan 17, 2005 11:03 AM
Se-rv-Tak
Dec 11, 2003 06:10 PM
spun Vtec
25
Dec 21, 2002 05:46 AM
