EG power window switches dead?
Old Feb 23, 2004 | 08:34 PM
90Hatch's Avatar
Default EG power window switches dead?
my friends coupe's window switches just don't work anymore.. he checked the fuses and everything and I was wondering if anyone has had any problems with this.. Like what could I check? and if anyone has a passenger side window switch.. let me know.
Old Feb 23, 2004 | 08:42 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: EG power window switches dead? (90Hatch)
I think the easiest suggestion would be process of elimination in attempt to find where the problem is. I would suggest attempting to borrow a switch from another friend or individual first to see if it is something as simple as a switch. Has he anything else in the car sudden stopped working that might correlate to this problem? If it's not the switch I would suggest checking the relay, then the wiring, since the fuses have already been tested and/or checked.
Old Feb 23, 2004 | 08:47 PM
90Hatch's Avatar
Default Re: EG power window switches dead? (INVALID)
nothing else went bad.. so i guess maybe have to check the swithces with someone elses. any others?
Old Feb 23, 2004 | 09:32 PM
tweedersc07's Avatar
it happened to me, i couldn't find **** either so i went to honda's only and got a new driver side switchs. still need to get the passenger side switches. but it cost me 65 bucks. damn ray and his high prices
Old Feb 23, 2004 | 10:40 PM
90Hatch's Avatar
Default Re: EG power window switches dead? (tweedersc07)
thanks for the input, so i guess i just need to get new switches.
Old Feb 24, 2004 | 04:50 AM
93CivicSI's Avatar
Check and see if there is any carbon build up on the contacts for the switches!
Old Feb 24, 2004 | 01:56 PM
90Hatch's Avatar
Default Re: EG power window switches dead? (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI &raquo;</TD></TR><TR><TD CLASS="quote">Check and see if there is any carbon build up on the contacts for the switches!</TD></TR></TABLE>
isn't it just a clip. that clips on.? what about if the passenger side isn't hooked up.. would that make a difference?
Old Feb 24, 2004 | 08:34 PM
90Hatch's Avatar
up
2sLoJR
13
Jun 23, 2013 01:48 PM
drew and not u
Jun 28, 2008 06:56 PM
IDriveHonda
11
May 12, 2005 09:52 AM
TheIntegraGuy
May 15, 2003 06:18 AM
Leets
Jan 3, 2003 12:13 AM
