jdmshit carbon fiber hood - gap on side - need help..
I ran into problems with a gap on the left side of my jdmshit cf hood..
Wanted to see if anyone had any ideas as to remedy this gap..
As you can see the gap starts at the bottom left side of the hood.. Is there anyway to cure this? The right side fits flush and there is hardly any gap..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intenseEK »</TD></TR><TR><TD CLASS="quote">ouch... not tryin to be a dick but jdm****</TD></TR></TABLE>
agreed
agreed
JDMshit.com sells quality equipment and has a great reputation among users of this site.
Have you tried adjusting your hood stops at the bottom? I know my hood fit pretty poorly until my brother pointed out that someone had fucked with my hood stop. Fixed it in about 10 seconds. Before freaking out, I'd look into that. Also, it's not the easiest thing in the world to align a hood correctly on the first try. Play with the bolts and such and see if you can make a constructive change.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">JDMshit.com sells quality equipment and has a great reputation among users of this site.Good luck.</TD></TR></TABLE>
yeah i thought the hood was a perfect fit from what i have heard
I don't know why people say JDMshit has a good rep. I bought some spoon replica mirrors and they fit like crap, theres 3 screws to screw the mirrors on well you have to force the screws holes to line up because they were so off. And my friend bought a replica spoon duckbill and it stuck up almost an inch above the roof of the car it wasnt even close to being flush. Maybe you should try to return the hood and get a full carbon fiber hood from jdmhondaparts... I've heard their hoods have fit fine.
compared to my VIS, my friends jdmshit is as it reads. But for the price you cant beat it. You get what u pay for i guess.
i agree with adjusting the hood stops..trying adjusting them to make the hood flush or somewhat level and perhaps look into putting some small shims between your hood attachment bolts and the hinges near the windshield..i had to use 1 small shim per side (between hood and latch on bolt closest to winshield) to make my hood fit perfectly. mind you, it's not a jdmshit hood. good luck bro.
Hmmmm JDMSHiT is the ****
everything i bought from them gave me no problems i dont know if its cause im black(haha) or what not but everything is fine for me and I had the same problem you had(not with their hood) and all i did was switch my bracket and everything was all Good
JDMSHiT=
oh yea and Talk to Newman b4 you Talk **** or put JDMSHiT on Blast!
JDMSHiT=
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDieM »</TD></TR><TR><TD CLASS="quote">Hmmmm JDMSHiT is the ****
JDMSHiT=
I agree. Everything I've ever gotten from them has been perfect, and I'll be placing the order for my hood very soon. Just PM Newman and I'm sure he'll help you out.
JDMSHiT=
</TD></TR></TABLE>I agree. Everything I've ever gotten from them has been perfect, and I'll be placing the order for my hood very soon. Just PM Newman and I'm sure he'll help you out.
mine did the same thing but not quite that bad. i emailed newman from jdmshit and he said to try to adjust it the best i can and if that doesn't help to use a stack of books when the weather gets warmer and it should take better form. i must say though for the money i can't complain.
thanks guys for the advice.
Where are these hood stops that you guys speak of?
and yes I do plan on getting hood pins..
Also I have no complaints with my purchase, so this thread is not nocking jdmshit at all.. I have just run out of ideas in trying to adjust this..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Im Rick James »</TD></TR><TR><TD CLASS="quote">Mine did that ...Have you pushed it back then try and re tighten it ?</TD></TR></TABLE>
You mean loosen the brackets that hold down the hood push back and retighten?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 »</TD></TR><TR><TD CLASS="quote"> But for the price you cant beat it. You get what u pay for i guess.</TD></TR></TABLE>
exactly. alotta their stuff is pretty cheap (pricewise, not qualitywise.. although it might be both).
hood stops, Its those little black rubber bump thing next to you corner lights and fender, you should see it its black and its a rubber piece sticking up ar each corner of the hood where your corner light meets.
To adjust your hood down twist the hood stops the the right
To adjust your hood up twist the hood stops to the left
hopefully i helped some
-dara
jdm5h!t =
-dara
jdm5h!t =
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnebadJdmEg6 »</TD></TR><TR><TD CLASS="quote">hood stops, Its those little black rubber bump thing next to you corner lights and fender, you should see it its black and its a rubber piece sticking up ar each corner of the hood where your corner light meets.
-dara
jdm5h!t =
ah i see, i'll try this out. thanks for the explination.
-dara
jdm5h!t =
</TD></TR></TABLE>ah i see, i'll try this out. thanks for the explination.
-dara
jdm5h!t =
I tried adjusting the hood stops.. Still nothing, I even tried taking out the hood stop for that side, still nothing.
If anyone has any more suggestions, it would be greatly appreciated!
-dara
jdm5h!t =
</TD></TR></TABLE>I tried adjusting the hood stops.. Still nothing, I even tried taking out the hood stop for that side, still nothing.
maybe adj. ur hood latch, loosing up all the bolts on your hood latch and you can adj, them up and down. make sure not too low it might bust your headlights.
i found out the hard way with my stock damn hood!!!
try readjusting the hood like others said. loosen the bold on drivers side (side sticking up) and put some weight on the hood so that the side sits flush, or close, and tight the bolts again....see if that helps...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanHatch »</TD></TR><TR><TD CLASS="quote">maybe adj. ur hood latch, loosing up all the bolts on your hood latch and you can adj, them up and down. make sure not too low it might bust your headlights.
The hood latch on the hood, or the latch on the car?
</TD></TR></TABLE>The hood latch on the hood, or the latch on the car?
