Horn Help! Already searched
I'm not putting an aftermarket steering wheel or anything. My horn just stop working on me the other day. I think is the relay, because I don't hear click nose when I press it. I couldn't test the horn itself because my screws that hold the bumper is striped so bad I can't get them off. The helm doesn't tell you to check the relay. Is there any way to test the relay?
Have you checked the fuse? If you don't hear a click noise.. it's probably the fuse. If you have cruise control, it will not work either as they both utilize the same fuse.
I took out the SRS unit and discounted all the yellow wires. Do you think that will cause the horn not to work? According to the Helm, cable reel is inside the sterring, which I didn't mess with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KimChiKid »</TD></TR><TR><TD CLASS="quote">What does it mean when you press the horn and it at least makes the clicking noise?
means there is still some sort of connection being made...
</TD></TR></TABLE>means there is still some sort of connection being made...
My fuse is good and there is power, I checked it with a test light. The relay is not doing anything. I guess the reel is bad. I'll open up the steering up and test it out according to the Helm. I'll let you know, If that helps. I just bugs me, how did the reel when bad by disconnecting the SRS.
tei344
Nov 9, 2007 05:51 AM
frizzo
11
Jul 22, 2007 10:02 PM
) but that could be it as well...
