b20 with b16 head
Go to http://www.b20vtec.com. I had one and I was the fastest N/A honda in my area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GERM »</TD></TR><TR><TD CLASS="quote">it all depends on the build up. just bolting the two together will make about the same or even less than a stock b18c1 motor, but the low end will better.</TD></TR></TABLE>
b20vtec ownz b18c1 any day.. does not have to be built.
Munkyw3rkz.webs.com
if your dropping a stock head use the P72 one..more comp, unless you weld the chambers on the PR3 like me
Modified by SnoFlake EG at 10:55 PM 2/23/2004
does anyone know what i would need to get, after market that is, to make a b20/vtec reliable? i mean i know i could slap my B16 head on a b20 block, but what does it take to make it work? besides wiring the block for Vtec...need some help.
i only ask cuz im doing the work myself and trying to save on labor.
http://www.summitracing.com
arp head bolt studs # ARP-208-4303 $115.95
mr. gasket mls head gasket #MRG-3190G $69.95
http://www.whipfactory.com/lsvtec.htm vtec oil line/fittings $70.bucks shipped
http://www.full-race.com/pd_lsvtecdowelpins.html
vtec dowel pins (These dowel pins allow you to run a VTEC head on an LS (B18A or B18B) and B20 (B20B or B20Z) blocks without drilling into the VTEC head.) $45.
http://www.boomslang.us/obd2.htm
0BD2 to OBD1 Jumper $75 shipped
http://www.b20vtec.com/forsale.html P28 ECU programs
chipped p28
http://www.andale.com/store?si...atId=
vtec distributor or u can jus shave off an ear on the b20distributor like i did and save that $259.
Modified by Mulan at 4:38 AM 2/24/2004
chipped p28
if you use the lower comp b20b, it will be very comparable to a b18c1 and will be way less reliable for high rpm use. basically, if you are not goin gto at least change the rods, get higher comp pistons, and arp headstuds, i see no point to building it. reliablility and decent power can both be had from a stock c1 or h22.
i love the b20/vtec motor, i just feel that its not worth just slapping the two together with no precationary measures.
totalfxaccord
Mar 21, 2004 11:46 AM
