Clutch help *searched*
Hello..I need some quick help. Been doing some searches but I cannot come up with any solid info.
My car is a 93 coupe. 5 speed.
Engine in is a d16y7 on boost. 10 psi.. Stock clutch is obviously not cutting it.
My tranny code is an S20. Which clutch do i need to buy. Options. Are there differences between the generations in the clutches?
Thanks.
Thanks.
to be on the safe side, buy a clutch from wherever that tranny came from, im not too familiar with tranny, but the clutch just needs to have the right number of bumps in the middle to fit the trannys stick thingy=].
Re: Clutch help *searched* (Pothole987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pothole987 »</TD></TR><TR><TD CLASS="quote">Almost positive that 1.6l from 92-2000 share the same clutch.
How positive? I appreciate the help.
with a little research i found out that the s20 tranny was the z6/y8 tranny. so just go find a clutch for 92-95 civic si/ex, or a 96-00 ex. Thats for 100% positively fit.
Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">92-00 all the same </TD></TR></TABLE>
Thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin »</TD></TR><TR><TD CLASS="quote">with a little research i found out that the s20 tranny was the z6/y8 tranny. so just go find a clutch for 92-95 civic si/ex, or a 96-00 ex. Thats for 100% positively fit.</TD></TR></TABLE>
Also, thank you sir.
Thank you.
