push button starter?
anyone know off hand what two wires i need to clip and attach to my push button starter off the back of the stock tumbler? any help is appreciated.
Re: push button starter? (dart2.2)
I'm not sure what you're doing, but if you have a test light you can trace the +12v constant signal. I'm not sure which wire is the starter wire, but run +12vto the test light and then find the ground. As long as you don't hood the +12v to ground you'll find out which one starts the car. Simply connect the +12v wire to the rest of the wires one at a time and eventually you'll engage the starter. Make sure the car is in park/neutral and/or make sure your foot is on the clutch so the starter will engage. If you're looking for a push button start you can get one from cole hersee. The make switches. The part # is 58022-03. This switch is (off-on-momentary on). So your ignition is (off-on-start). You can wire everything into one switch. Eliminate the lock in the steering wheel and you no loner have to pull your keys out to start your car. Get an alarm that senses the transmitter as you approach and you'll never have to pull the keys from your pocket again. The car knows you're the one who is supposed to start it. Good luck.
mafia
06-06-2014 11:26 AM
Canadian_EF
Audio / Security / Video
07-23-2012 09:04 AM
spoolin_eg
29
06-11-2011 06:09 PM
