Code P1337 Crankshaft Position Sensor
I have a check engine light and this is the code im getting for the CEL (P1337), Its the crankshaft position sensor! I have been told i can do a splicing trick on the ECU to fix this problem but will it get rid of the check engine light? People are saying that this sensor is by the valve cover and other people are saying its in the oil pan connected to the oil pump? Does anyone know the best way to get rid of the CEL so i can get my car inspected!
OK Well i have done the CKF bypass trick and i still have the CEL, i also checked the haynes manual and it says that code P1337 is the crank fluctuation sensor....not the crankshaft position sensor! Ao the guys from autozone were wrong?
IM tottaly stuck here and lost...anyone got any info on what to do? SHould i change the crank fluctuation sensor?
Modified by markovwgti at 9:53 AM 7/24/2008
Seagull Management
Re: Code P1337 Crankshaft Position Sensor (markovwgti)
Here is the sensor http://www.ff-squad.com/tech/sensors/ckf.jpg
Here is the CKF bypass trick http://technet.ff-squad.com/ckftrick.htm
For this and just about anything else you've ever wanted to know about honda sensor locations and electrical info checkout http://technet.ff-squad.com/
form51
13
03-16-2020 02:52 PM
pityocamptes
12
12-14-2011 09:48 AM
underb00steg6
04-01-2009 11:13 AM
saywhat
12-05-2004 09:41 PM
N1NjA TuRtLE
12
06-05-2004 08:30 PM
