throttle cable bracket
Hello everyone,
Need info about the throttle cable bracket to use in a EJ hatch 96-2000 (d16y7)
with a B dhoc engine..
to fit perfectly with the existing DXcable
Thank JL
Thank JL
if this was my post it would've gone like this.
Hey! I swapped a b18c into my 96 hatchback which originally had a d16, what bracket would i need to re-use my existing throttle cable?
then i would've replied.
oh we'd need to know WHICH F'N MOTOR CAUSE THE LENGTHS ARE DIFFERENT DEPENDING ON WHAT MOTHER F'N B-SERIES.
so yeah, how bout letting us know the specific motor, and either way i'm sure you'll probably end up needing to change the throttle cable and not the bracket.
I used prevously the dx bracket, just bend it at 90 degrees. it,s working, but
only one bolt retained the bracket in place
I will try the b18c5 bracket...it will fit... proprely...
i think so.
Modified by JLCivixHBDX at 1:43 PM 7/27/2008
i think so.
Re: (JLCivixHBDX)
I got the same problem with a 96 dx and a b16a swap. The previos owner put in the b16a and I think it has the stock throttle cable and he told me it had a LS throttle body. The cable is too short and it keeps the TB open and it idles at like 3k.
Does anybody know what I can do to fix it. What throttle cable should I use.
Re: (Lil Gnome)
im pointing at the injectors but were not looking at that are we...
i stuck it in a vice and just hit it with a hammer till it worked. i have a Y8 manifold, the TB cable is coming out of an ej1, with a d16z6 motor. its only got one bolt (i should dremmel it out now that i think about it...meh...) and thread lock. its been holding steady forever you could do that....
i was in your shoes, nothing was working out just right aaand i just started messing around, one thing lead to another she bougt me some drinks went to her place and boom a bracket that worked
Re: (instrument)
Man while I was reading this I fell to the floor laughing my *** off, Man you cracked me up with this reply
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">if this was my post it would've gone like this.
so yeah, how bout letting us know the specific motor, and either way i'm sure you'll probably end up needing to change the throttle cable and not the bracket.</TD></TR></TABLE>
