ls vtec?
ls vtec?
got a ls vtec,,, theres a hose in the back of the head that suppose to go to the oils vauum resevior or some like that,, but the ls block doesnt have,, wat am i suppose to do with the head????? so i block the hose or bypass it????
thanks
thanks
Re: ls vtec? (crxrj)
If you are looking at the back of the head then the hose that comes out of the right side of the head should be put into were the oil pressure sensor goes. some elminate the pressure sensor and others T it off but either way the head has to get oil through a certain journal to get the vtec.
well i got th hose from the block to the head,, but the hose comes from the manifold... i used to have plugges in casue i had an older ls now i got a b1 n doesnt come with the black box... thanks for lookin
Not to be confused with "THE MAN"
Re: (crxrj)
Your block is a automatic. You need to run a breather tank like I did. I just put my PCV valve in there. You can buy one like mine at ENDYN web site They will come with vents that go in the back of the block to hook up to the tank.
Vent lines.
Tank setup.
Vent lines.
Tank setup.
pakn-heat
12-01-2009 04:17 PM
