system too rich code p0712 comes on in my 98 civic dx after i did a jdm b16a swap..
system too rich,code p0712 keep on in my 98 civic dx after i did a jdm b16a swap.
anyone can help me please.....
Mr. Badwrench
Re: system too rich code p0712 comes on in my 98 civic dx after i did a jdm b16a swap.. (jinbeyond)
what ecu?
if you are using a domestic ecu, did you convert the engine to obd2?
how are the o2 voltages? is the fpr ok? lotsa variables. and we need a little more info.
Re: system too rich code p0712 comes on in my 98 civic dx after i did a jdm b16a swap.. (boostedcivi
i am using a integra type R ecu on it,the o2 sensors are fine,no o2 cels come out yet,and also the evap still not ready
yes,i think i did convert it to obd2,i cut and splice an OBD1 alternator plug and mate it to my OBD2 EWH ,Convert to OBD1 injector plugs by cut/splicing OBD1 injector plugs to your OBD2 EWH,also using a obd2 Distributor,car runs good but the idle jumping up and down when the engine cold
Mr. Badwrench
the o2 voltages cant be ok if you are getting a rich code. you mean p0172? p0712 is auto trans temp.
since the car has no mass air, it looks at the o2 reading. you may have a lazy o2 sensor.
Mr. Badwrench
since you converted also, you are missing a ckf, i dont think that has anything to do with it yet.
i did the ckf sensor with the oil pump changed, yes you are right,it was p0172
Mr. Badwrench
since you are using an obd2 ecu, get a scanner and look at your fuel trims, and see if the o2 voltage is fluctuating. if it is solid, you have a lazy o2. give it a vacuum leak and see what it does, if it is still not moving, replace the o2 with a known good one and see from there.
i did check the o2 voltage,they look like what you said---lazy o2,fuel trim both ST and LT are nagative,i was thinking is that the ITR ecu HAS problem or not going to fit for my swap,so i replaced it with a GSR ecu,then the o2 voltages are look normal AND THE FUEL TRIM STILL NEGATIVE BUT BETTER THAN BEFORE , i will see the cel coming back on or not when the system gets ready,it may takes couple days drive,THANK YOU FOR YOUR REPLY,I MAY NEED YOUR HELP LATER AGAIN
marcj
12-27-2008 03:50 PM
benphillips
11-29-2006 09:19 AM
