c.e.l. help!
Old 07-25-2008, 07:50 AM
drew_kousk's Avatar
Default c.e.l. help!
ok i know how to get the light to blink n what not but i cant really tell wats the codes.
so if anyone can help..
heres a video!
thanks. and if you can possibly a suggestion in fixing the problem also!
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Fbwyl6JgGT0&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/Fbwyl6JgGT0&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Old 07-25-2008, 07:51 AM
drew_kousk's Avatar
Default Re: c.e.l. help! (drew_kousk)
dam video didnt go through but heres the url just to copny and paste into address bar! once again i appreciate the help
http://www.youtube.com/watch?v=Fbwyl6JgGT0
Old 07-25-2008, 08:12 AM
drew_kousk's Avatar
anyone?
Old 07-25-2008, 08:14 AM
BlackoutVTi's Avatar
https://honda-tech.com/zerothread/1901557
That should help you tell what the codes are besides blinking lights
I'm seeing 6, 19, and 21. Oh, also, what's the year of your car? Is it OBD1 or 2a/b? I would ASSume OBD1 since you're doing the blinky light thing.
In that case, 6 is the water temperature sensor, 19 is Automatic transmission lockup control valve, and 21 is the infamous VTEC spool solenoid valve. You can find out more by clicking the link and learning more about CELs for your car.
Modified by BlackoutVTi at 9:24 AM 7/25/2008
Old 07-25-2008, 08:29 AM
drew_kousk's Avatar
Default Re: c.e.l. help! (BlackoutVTi)
ok i tried it 2 see and u gave me the same ones i had written down,
now how would i go about fixing these? if u can help in that
and problem with # 19 is my car is manual transmission
i have a d16z6 with p28 ecu
Old 07-25-2008, 08:38 AM
OMGWTFBBQ!'s Avatar
Sounds like you have an Automatic ECU running a Manual car.
When I did that on my D16Y8 I got all kinds of CELs for the auto tranny that wasn't there.
Old 07-25-2008, 08:40 AM
drew_kousk's Avatar
Default Re: (OMGWTFBBQ!)
ok wen i get my ecu chipped ill fix that 2.. umm and for #s 6 and 21?
Old 07-25-2008, 08:44 AM
Default Re: (drew_kousk)
Well, for 21, you're solenoid could have gone bad and will need replacement (3 bolts and a gasket), or you may have a loose ground or bad connection to it.
Same goes for the water temp sensor. You will either need to check connections, or replace the sensor.
Old 07-25-2008, 08:45 AM
rivaladore's Avatar
edit: SORRY didn't read down didn't think anyone responded to him
ok looks like you are throwing codes 21, 6, and 19
jarthe3
03-27-2015 12:14 PM
on-site ej1
07-20-2009 12:26 AM
mstyper
Acura NSX
01-15-2005 02:36 PM
bimmerdude
02-13-2003 11:15 AM
Quick Reply: c.e.l. help!
