HOW TO : DIY EK Hood Dampers using eg rear window dampers - Honda-Tech - Honda Forum Discussion
Old 07-24-2008, 06:44 PM   #1
importnoodles's Avatar
Default HOW TO : DIY EK Hood Dampers using eg rear window dampers
***** use a thicker metal than the one i used
*****also, i found that the hardware store had some thicker pieces of metal that were already 90 degree angles.... if you use those, you dont have to do any bending, only cutting, so it's easier.
dampers were bought used for 15 bucks and total cost was under 20 bucks......
do you need it? no
is it necessary? no
y did i do it? boredom
enjoy...
ok here is the first attempt.....
Behold my almight k20 people are talkin about
get your dampers and scrap metal.... i used a kind of a thin sheet so that i could bend easily for first measurements
Get your dremmel and extension cord
Now, the placement of the dampers in NOT going to be ON the fender as some people (such as me) may think
We are goin to put the damper NEXT to the fender like this..
now both sides of the damper have these washers..
one of these washers is larger than the other, I cut this larger washer off because i though it may make the installation easier.
now we are going to need a l bracket so i ghettoed this one.
in my first attempt i drilled the hole so that the damper would mount right next to this bolt as you can see
my original measurements looked like this.
bolt and grind everything up and it should look something like this...
I DID realize that mounting the damper HIGHER above the bolt will give the damper More leverage in opening the hood.
so my finished results will be mounted higher up with thicker metal which i will update when i do finish it.
now to the bottom mount.....
well the piks are actually self explainatory so take a look
another l bracket is needed.
there you go. some final notes, the thin metal i used flex'd a lot. i just bought some thicker metal which i will update when finished.
also the bottom mount will be about an inch closer to the windshield in the final product. the upper mount will also be about an inch higher to increase the leverage of the dampers... the driver side damper is basically the same
second attempt is finished...... some notes to consider
1. the thicker metal holds up bit better, but the hood mount could still be thicker
2. the new metal that i used for the lower mount is good enough
3. when mounting the damper bolt above the hoods bolt, make sure not to mount it too much above the hoods bolt, because it will cause the shock to "bottom out" when you close the hood, forcing the hood mount to bend or cause worse damage.
4. close the hood slowly and look at the damper to make sure it doesn't bottom out
As you can see here, the mount got bent because the damper was mounted too high, the damper "bottomed out" and bent the mount. I slid the mount lower and it fixed the problem.
Modified by importnoodles at 12:57 AM 7/25/2008
Modified by importnoodles at 12:59 AM 7/25/2008
Modified by importnoodles at 2:08 AM 7/26/2008
importnoodles is offline   Reply With Quote
Old 07-24-2008, 06:55 PM   #2
Location: ....................................................................................................
not bad very nice write up ^^^ but myself personally would just stick to the original hood latch so i don't have to mess around with to get the fender off and what not
blkegcoupe is offline   Reply With Quote
Old 07-24-2008, 07:03 PM   #3
Default Re: (blkegcoupe)
i never took the fender off...
just slipped the mount under it and bolted it down.
Old 07-24-2008, 08:29 PM   #4
EkFG's Avatar
Default Re: (importnoodles)
EkFG is offline   Reply With Quote
Old 07-24-2008, 08:33 PM   #5
iluvmy2000civicex's Avatar
Default Re:
Kool... and nice write up. I think youre being tricky though cuz that looks an awful lot like a d16y7 more than it does a k20 haha.
iluvmy2000civicex is offline   Reply With Quote
Old 07-24-2008, 08:41 PM   #6
EG8R's Avatar
Default Re: Re: (iluvmy2000civicex)
Wash the engine bay too while you are at it... Yikes.
EG8R is offline   Reply With Quote
Old 07-24-2008, 09:14 PM   #7
Mingo's Avatar
Default Re: Re: (EG8R)
Quote:
X2 nice write up though
Mingo is offline   Reply With Quote
Old 07-24-2008, 09:18 PM   #8
The Lobster's Avatar
Quote:
not sure what you are reading...but he didnt take the fender off..
VERY GOOD DIY i paid 110 for my tiens dampers.
but very nice none the less. I always told my friends that this could be done with rear eg shocks...but most of us were to lazy.
props
The Lobster is offline   Reply With Quote
Old 07-25-2008, 12:25 AM   #9
Default Re: (The Lobster)
thanks for the replies guys.. yes i know. im a dirty wh*re. just too lazy to clean it. but it's ok, i always run mobil1 full synthetic and Honda MTF. It's clean on the inside and thay's all that matters thanks for lookin
Old 07-25-2008, 03:05 AM   #10
VRD^sam's Avatar
Nice write up, but you should really block your VIN #
VRD^sam is offline   Reply With Quote
Old 07-25-2008, 05:15 AM   #11
addiction2bass's Avatar
Default Re: (VRD^sam)
why not try to match the MADE FOR hood mounts?
i bought my tein hood dampeners and its a much cleaner instal and the mounts are solid.
urs wouldnt look to bad if you used heavier steel and grinded the edges smooth and painted them.
just get some good size angle iron once you have the right locations figured out for the struts travel length.
addiction2bass is offline   Reply With Quote
Old 07-25-2008, 06:46 AM   #12
Nbboy7's Avatar
nice lol will this also work for the egs
Nbboy7 is offline   Reply With Quote
Old 07-25-2008, 10:06 AM   #13
Default Re: (addiction2bass)
"MADE FOR" mounts that come on the already made kits are difficult to make. if you compare them to the eg dampers, the ends of the eg dampers are bolts which you put a nut on to tighten. the ready made dampers have a cup at the ends, which secure to a ball mount. That kind of stuff cant be ghetto rigged.
Old 07-25-2008, 10:44 PM   #14
jers99's Avatar
Default Re: HOW TO : DIY EK Hood Dampers using eg rear window dampers (importnoodles)
good DIY but man simple green is all I can say.
jers99 is offline   Reply With Quote
Old 07-26-2008, 01:30 AM   #15
GaB
GaB's Avatar
If u do some paint on the shock, like tein's green color it will be a very good looking!
good DIY, love it!
GaB is offline   Reply With Quote
Old 07-26-2008, 01:57 AM   #16
FamousRacingInk's Avatar
i like your style. trick look with budget in mind.
FamousRacingInk is offline   Reply With Quote
Old 07-26-2008, 07:48 AM   #17
The Collin's Avatar
Nice idea. Cleaner cuts would make it look a lot better. $20 could have been invested in cleaning the motor thouroughly, having lunch, and a movie. But, good write up nonetheless.
The Collin is offline   Reply With Quote
Old 09-25-2008, 08:14 AM   #18
shaggyeg6si's Avatar
Default Re: (99_hb_on_air)
just did this on a 98 awd manual crv. I couldnt find the 92-95 hatch shocks, so I used 95 Acura Legend hood dampeners instead. This was great, and saved me from having to make a bracket for the hood, so I only had to make 1 Bracket for each side!
shaggyeg6si is offline   Reply With Quote
Old 09-25-2008, 08:17 AM   #19
Default Re: (shaggyeg6si)
So instead of buying those $100+ Tien hood dampeners, and after waiting for a set in a trade for a few weeks, I got tired, and went and got some hood dampeners of a 1995 acura legend and fabed them on the crv. I was looking for 92-95 civic hatch glass struts, but couldn't find any.
So the legend struts made it so I only had to make one bracket for each side. The dampeners were $8 for the set, and some grade 8 bolts, nuts and washers were about $2, so a total of $10 and some change for hood dampeners! I also needed a metal bar of some sort. I had a piece of steel lying around at work that a co-worker had used to make a lock set up for his tool box, so i used about 6 inches of that.
They bolt to the hood bracket as any normal set would, and right up front on the fender itself. The bracket is on the fender lip (under really) between the two front fender bolts right next to the vin sticker. The bracket goes straight out, and the shock connects there. I painted the bracket black and did have to drill a hole for the bolt, but it looks fine. I was planning on only drilling a hole under the fender line, so it could never be seen, but that specific area is unreachable to put a nut in, because its behind more metal, and I didn't want to make an access hole. So now the bracket is just samwitched around the fender lip. Thats why the grade 8 bolt. So I could tighten it enough, and not brake the head off the nut, which I did, right before I went and got the grade 8! I obviously had to provide the nuts for the "bolt" (round top that the dampener clips over) the dampener connects to on the bracket as well, because that is actually screwed into the vehicle it came off of. I think I used an exaust/cat bolt.
Modified by shaggyeg6si at 8:23 AM 9/25/2008
Modified by shaggyeg6si at 8:26 AM 9/25/2008
Modified by shaggyeg6si at 12:31 PM 9/27/2008
Old 12-11-2008, 04:47 PM   #20
Default Hood Dampers
Another set to use are from a del sol.I have them on my 96 hatchback and my buddy has them on his 01 integra type r.Weve put them on a bunch of integras and civics.
banditdog is offline   Reply With Quote
Old 12-11-2008, 05:17 PM   #21
preluderemis's Avatar
nice write up...had some rear window dampers laying around...now i know what to do with them
preluderemis is offline   Reply With Quote
Old 12-12-2008, 11:07 AM   #22
Both setups look nice...Nice write Up too
EKing is offline   Reply With Quote
Old 12-12-2008, 01:04 PM   #23
teamworxek9's Avatar
if i were you and i was bored i would have cleaned my engine bay first. but good diy. the second one is way cleaner.
teamworxek9 is offline   Reply With Quote
Old 12-12-2008, 05:00 PM   #24
cruizinmax's Avatar
So will these actually push the hood up, or do they just hold it up after you have already pushed it up?
cruizinmax is offline   Reply With Quote
Old 12-12-2008, 08:18 PM   #25
E+J+M=LOVE's Avatar
nice, me and my brother tried it on his ef9 but no success ;( but this thread is giving me more hope. i will try again. any in put for ef9 dampers??
E+J+M=LOVE is offline   Reply With Quote
Rays Duralumin Lugnuts ek99civic For Sale 4 02-27-2009 12:48 PM
05-06 RSX Drivers Side Headlight ek99civic For Sale 5 02-12-2009 09:32 PM
It's Hammer time!!!! ....................i mean, clean up time. importnoodles Honda Civic / Del Sol (1992 - 2000) 30 12-26-2007 11:22 PM
FS..... JDM WedsSport sa90 16"x7" 4x100 bronze immaculate condition importnoodles Southern California (Sales) 0 09-13-2007 12:35 AM
2005 Type-S SKUNK2 MEGA POWER REVIEW Rev4Ever Acura RSX DC5 & Honda Civic EP3 85 05-27-2007 01:11 AM
Tags
9900, bolt, car, civic, d16y7, damper, dampers, diy, engine, hatch, homemade, honda, hood, parts, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
