Running Lean
Running Lean
Hi got a question I just checked my spark plugs and the tip of them are white... i am not loosing any coolant but I am burning oil very little with royal purple 10w30. I have a b16a3 with 140k on it always use 92 octane just recently started using 94.
Re: Running Lean (jit01)
bump for a fellow BC boy,Do you drive in vtec lots?I had the same thing and i found out i had low compression in one cylinder goodluck.Ask on vcc they might be able to help to(Vancouvercivics.com)
Nope dont go in vtec a lot. I did a compression test i think a month and a half ago it was 220 on all 4 cylinders if i remember right. (It had white on the tip at that time also)
will post on vcc too
