92 civic lx wont start
I took my plug wires out to check and see if there was any oil in my tubes and when i went to live it wouldnt start up, it tries to cranks but i checked my distributor for metal chips and there were none and it is getting spark, any ideas on what is causing the car to not start?
Re: 92 civic lx wont start
i only took out the tubes, just to see if oil was in there with the spark plugs, and i put them back in the same spot, then the car wouldnt start
im not sure how to check that, i know you use a screwdriver but nobody will explain how to do it, i have called a couple places and they do a very bad job explaining it, if you could explain it i would really appreciate it
should also be for having a control subject. So you know what you're looking for, and how far off the others are from it. like the old "test a known good one"
alright i checked the main relay and it looks good and it clicks twice so i dont think thats it, im checking the plugs today in a few hours when i get paid, but any other suggestions
Any CEL codes?
Does the fuel pump prime (low humming noise) for 2 seconds when the key is turned to ON(II)? If so, remove the coil and igniter unit from the distributor. Test the coil (see below) and take the igniter unit to an auto parts store for testing.
any idea how much an ohmmeter cost, im sorta in a bind with money, every little thing on my car messed up at once and i have just been spending every little bit of money i have on it right now, since im in school its hard to get alot of hours in but im trying so i appreciate everyones help.
You should be able to buy a basic digital multimeter for about $15 if you shop around.
As money is tight right now, try instead to borrow a multimeter from a friend or alternatively phone some auto parts stores to see if they will also test your coil.
Beegee208080
24
06-03-2012 06:53 PM
wanna b R
08-25-2004 01:02 PM
itsm3paul
05-10-2004 12:49 PM
