Megan gauge wiring diagram??
So i bought these gauges off a friend and he never used them. they are megan racing gauges. but he lost the wiring instructions. any kno how to hook these up?
Boost gauge. i kno where the vacuum line goes lol
air/fuel gauge
Oil pressure gauge
thanks guys.
air/fuel gauge
Oil pressure gauge
thanks guys.
1 Post
Re: Megan gauge wiring diagram??
Red - Switched 12v source (Fuse box, acc wire, headunit wire, etc...) All can be daisy chained together into one wire.
Black - Ground (All can be chained together as well and grounded into one point on your chassis)
Oil Pressure: Orange should be to your headlight and purple to the sender.
I use Glowshift gauges but hopefully their instructions should be similar to your gauges. Here is a link:
http://www.glowshiftdirect.com/GlowS...l-Support.aspx
Use the instructions for the regular TINTED SERIES. Also, Do not wire them up to a 12v constant as said in the instructions (the gauges would always be on if you wired them that way). It's a mistype that has yet to be corrected. Your power wires should go to a SWITCHED 12v source.
Hope these help.
Hope these help.
