fuel pressure dropping quick
I have a quick question for you guys.
I noticed that my fuel pressure (on stock gsr motor) drops down to 0 in 15 minutes to 1/2 hour after I shut my car off. Is this normal? I was told that the fuel pressure doesn't drop as quickly as it is on mine.
Re: fuel pressure dropping quick
check for leaks around the lines and rail. if not, then your injectors are leaking a way to check that is to take out the whole rail with injectors on. koeo and see if fuel leaks from the injectors
hybridpatient95
15
02-10-2006 07:03 AM
saer
06-03-2005 04:17 PM
