thermostat or fan switch?
94 Honda Civic EX, stock motor.
When my car is sitting at idle for more than 5 minutes, it will heat up beyond where it normally sits. While it is overheating, the fan is not on.
Here's what confuses me, after i rev the engine a little, the gauge will start to drop to where it needs to be, and THEN the fan will kick on. If I let it idle again, the fan will turn off eventually and then it will start to rise again.
I drive twenty miles a day and it never rises while driving, or sitting at a stoplight for a minute or two....just prolonged idle.
The car has a brand new fan, radiator, hoses, water pump. Only thing that I know wasn't replaced was the thermostat and fan switch. Although i'll probably get them both replaced, im kinda curious as to which is the actual problem and why.
Re: thermostat or fan switch?
you have a bad thermostat
what i would do is just get a switch for the damn thing.. thats what im gonna do, b/c that used to be my problem.. drive and it wont overheat.. but getting caught in traffic.. and the temp rises a lot until i start driving again
Check the coolant level in the radiator and then bleed the cooling system of trapped air.
Bleeding the cooling system:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
This procedure may take 20-30 minutes:
thanks Ron, but i know how to do it. lol. i just wish i had a bleed bolt, so i didnt have to wait like 15 minutes for my damn thermostat to open up
It takes about the same amount of time with or without a bleed bolt because in both case you still need to idle the engine until the fan comes on twice.
RonJ, thanks for the suggestion! I added about half a liter of coolant, bled my system and can no longer duplicate the problem....my fan kicks on when it should and everything runs cherry!
rice a roni
08-19-2007 05:54 AM
