speedometer not working need vtec back!!!
just had a swap done before the swap everything was working fine now after the swap my speedometer doest work just installed a new vss and still having problems i also checked the fuse and its good on the cluster my srs light is on the cruise control is on and rpm and temp works fine ned help asap
Re: speedometer not working need vtec back!!!
it is a 5 speed im sure i got the right one cuz i brought the 1 that i took out and they gave me the same 1 can there be sumthing else?
well if the srs light is on take the bulb out and poof its dissapears as far as the rest maybe u just have a busted cluster
ok i forgot to mention that when i pulled up the codes before i swaped the vss it had P0500 Vehicle Speed Sensor (VSS) Circuit Malfunction AND P1337 Engine Speed (RPM) Fluctuation Sensor No Signal rpm works fine
well 1st thing use the paper clip method of getting ur codes scanners are not always correct but the paper clip trick is always correct. count the blinks and use the faq's and stickys to get ur info from there
