master cylinder relocation..?
hey everyone, I wanted to get some input on my project. the resevoir is in the way, any ideas on how to put it somewhere else? I'd like to keep the booster in place..
and I'm gonna need a hood idea too..
thanks in advance..
thanks in advance..
Re: master cylinder relocation..?
relocate the resiviour. If you have a machine shop nearby im sure they could make you an adapter plate that would shift the resiviour location an inch towards the fender. Simple CNC job really. maybe cost ya about 100 bucks for material and labor.
kinda, heres what im thinking
(im busting out the uber MSpaint engineering here hold on)
Okay take a block of aluminum say 2"tall, 4"long, 3" wide. Have a shop machine it so that there is a pathway (the yellow) in the shape of an "S". The bottom part goes on your master cylinder, and your top hole is mounted to your resiviour. You might need to tweak the dimmensions to have it meet your needs, but it should work.
your going to have to pull some custom work with that hood, i would suprised if anyone makes a hood with a spot that big.
You are correct, jrsc mated to an F20b w/blox stg 2 cams, h2b, 01 itr trans, 4.7 FD, all the other bolt on goodies blah blah.
the jrsc has been sitting for about 3 yrs so I said wthell. as for the hood, ya I know. maybe I can find a beat up 00 hood for cheap and make a scoop from it..
Ill get started on the mc trick, maybe I'll be one of the few guys on here with a one of a kinder.. oh ya has a/c too.
Why not change the bracket on the engine or use like a racing brake setup that goes under the dash?
How far does the junk stick up? Maybe make a big bulge in your hood like some of those DSMs have.
it sits about 5 inches above the fenders.. you guys are cool to give me such good ideas.. I'll keep you up to date..
I'm not Rick!
how bout a boosterless MC
from www.kenskustomchassis.com
$130 shipd. itl work for you. and yes you will still have good brakes...so iv heard from 2 people that have 9 second sfwd cars that use them.
im pretty sure you cant just move your master cylinder and have it still function cause if you move the master cylinder your going to have to move the brake booster which you cant do cause it has a push rod connected to your brake pedal??
i agree with this guy
I can't believe nobody mentioned this but Wilwood makes a set of pedals with their own master cylinders...
http://www.wilwood.com/products/005-...lies/index.asp
whokid_911
26
02-12-2011 03:17 PM
booster, brake, civic, clutch, cylinder, cylindr, dash, front, honda, master, mastercylinder, relocate, relocated, relocating, relocation
