hollow sway bar?!
Flattery Will Get You Everywhere
hollow sway bar?!
so im looking to get an asr subframe brace/sway bar kit, and i found one that was a 32 mm hollow sway bar. doesn any one have any expirience with this? would it be worth it? whats the difference? and since i have itr lca's, would i get the itr kit, or the kit for an eg? thanks alot!
Re: hollow sway bar?!
Depending how it's constructed, I don't see what's wrong with it. Being ASR, it should be good. It may be cheaper to get get a used ITR rear bar and repaint it.
The majority of the stress in a sway bar is concentrated near the outside surface, so hollow is what you want. A solid sway bar is not an efficient design with regards to its stiffness vs. weight.
good thread covering this... https://honda-tech.com/forums/suspension-brakes-54/sway-bar-question-hollow-vs-solid-2302468/
it may not be the exact chassis or setup you have, but the principles still apply. (especially in the tech article posted by Tyson)
dgdarien
10
03-30-2003 01:09 PM
