Help OVERHEATING!!!
Help OVERHEATING!!!
ok so i decided to go on a vacation car i come back and my car when i sit gets a lil hot temperture gauge is up n when i give it gas even if im at a stand still iit goes back to normal. today it gets real hot n just clicked in my head my fan ainit turning on. the ar gets hot n when i give it gas the temperture goes back down but no fan. why ccould my fan not be turningn on? and how do i fix it? thanks
o n car is a 97 civic ex
Re: Help OVERHEATING!!!
Jump the connector for the fan switch on the thermostat housing. The fan should now run continuously. If so, replace the switch. Also top off and bleed the cooling system.
I bet you have a bad fan switch by the thermostat. If you short it, and the fan comes on its the fan temperature sensor. If it doesn't come on, your fan is dead.
power straight to the fan, if the fan kicks on, your switch needs to be replaced....the switch is located @ the thermostat housing. If you do not know where that is, take your car to a mechanic.
We can tell him where its at, we dont need to send him to a mechanic. If were going to have that attitude might as well tell everyone in the tech section to take it to a mechanic.
OP: It looks like this:
It is near the lower radiator hose that connects to the motor. There will be a harness connected to it.
Im sure you can get a replacement at any auto parts store. I dont know the exact size, but im GUESSING its probably a 21mm. It shouldnt be on super tight, so you shouldnt have much problem taking it off.
why thank u sir i appreciate it im pretty good at mechanics so i wouldnt need to ive switched my motor three times supsension rack n pinion transmissions i kno what im doing i was just curious as to where it was. cuz there is anothere piece just like that by the head on the b18 except smaller n only has one yellow wire to it . thanks again
B_1_8_hatch
01-23-2003 07:03 PM
