Check engine light won’t turn off
My idle air control code keeps popping up p0505 . I replace it over and over . I don’t have leaks . and the light comes right back on . I clear the code , light shuts off car runs as it should . Soon as light comes right back on the idle changes up and down . What else could be bad that I should replace . TPS ? Any suggestions
Re: Check engine light won’t turn off
Describe the idle problem.
If those are fine, start by adjusting the idle speed as detailed in the downloadable service manual.
If problem persists, Ohm test the ECT sensor and voltage test the TPS.
Actually I’m running my fan at all times rn . Could that be my issue . I have a paper clip in the switch so it stays on with key turned because I don’t have a sensor that works rn my car over heated I blew the head gasket but changed everything it’s up and running just having issue with that one code popping up .
There’s no leaks , I adjusted the idle speed , it stopped going up and down but the engine light still comes back on and says idle air control . It’s been replaced already
