2000 Civic,Cranking but not starting..HELP 😭
Old 06-02-2019, 05:25 AM
Pat_Ek1984's Avatar
Default 2000 Civic,Cranking but not starting..HELP 😭
My car has been down for now a month and I'm just stuck in what to do next...Please help out...
It's a 2000 Civic Sedan,swapped with a B20B.Been driving it for 2 years,it's the dd.I parked it up from coming home one Evening.Everything is Fine.I got a rental and went on a 2 day vacation with my family.So when I came home to start it,it just cranked and did not want to start roll over whatever..Did some testing checked the fuse boxes for anything blown..Tested for spark,and I'm not getting spark.So I had a spare dizzy laying in the closet so I swapped it in and Nothing.Just cranks no start..I put in New NGK wires and plugs.A New Cap and rotor in the Dizzy.Main relay clicks,fuel pumps turn on...And now I'm stuck here,don't know where else to look..It has a stepdown Obd1 p75, swapped a Obd1 P28 and still not starting..Guys help me out..
Thank you.
Pat_Ek1984 is offline
Old 06-02-2019, 12:14 PM
Pat_Ek1984's Avatar
Default Re: 2000 Civic,Cranking but not starting..HELP 😭
Still need help ppl.
Thank you
Old 06-02-2019, 03:59 PM
tamboo's Avatar
try testing coil and icm:
https://www.team-integra.net/forum/b...eshooting.html
bad coil is #1 no spark culprit, will fail sooner than icm.
i always carry a spare.
tamboo is offline
Old 06-02-2019, 04:40 PM
tony_2018's Avatar
Is the dizzy spinning?
tony_2018 is offline
Old 06-02-2019, 04:50 PM
Pat_Ek1984's Avatar
Yes it is.
Old 06-02-2019, 04:52 PM
Pat_Ek1984's Avatar
I'll have to check in the morning.
Old 06-05-2019, 05:13 PM
Pat_Ek1984's Avatar
I am not getting no spark man.
I'm at a road block here ...lol
Old 06-07-2019, 05:34 AM
muellersfan's Avatar
Also check whether fuse 9 is blown.
muellersfan is offline
Old 06-07-2019, 09:06 AM
Pat_Ek1984's Avatar
Going to take a look now..
Old 06-08-2019, 07:47 AM
Chrisfrom1986's Avatar
Thanks, saved me from unnecessarily taking apart my distributor.
Chrisfrom1986 is offline
Old 06-08-2019, 09:16 AM
Old 06-08-2019, 11:52 AM
can you hear the fuel pump prime when you turn the key to on but with out cranking? check the main fuel pump relay inside the glove box.
my fear is online now
Old 06-08-2019, 02:46 PM
Pat_Ek1984's Avatar
Yes it primes, and it clicks.
Old 06-10-2019, 07:35 PM
Pat_Ek1984's Avatar
Solved.
Purchase a brand new dizzy,**** it.
My car starts and drives.HOORAY
  • Ask a Question
Question Title:
Description:
