B16 swap Loom and Ecu setup
Old 05-31-2019, 07:28 AM
conor o h's Avatar
Icon7 B16 swap Loom and Ecu setup
Hello, Im just after swaping a b16a2 engine from a 2000 Em1 civic into an 1998 ej6 shell, I cant seem to figure out the correct loom and ecu set up, I know the ej6 chasis is obd2a and the loom from the Em1 is obd2b, so do I need to get an obd2a engine loom? What ecu do I use then without effecting the immobiliser, Im very lost any help greatly appreciated.
Old 05-31-2019, 05:33 PM
crookson speed's Avatar
Default Re: B16 swap Loom and Ecu setup
you need to find schematics and ecu pinouts for both cars and figure it out. Not hard just takes alot of time=]
Old 05-31-2019, 07:16 PM
Daniel Lindsey's Avatar
Default Re: B16a2 swap into a 1997 civic
I have a b16a2 swap with a d16 harness a an obd2 ecu can i just use a conversion from obd1 to 2 onto the ecu or do i have to replace the whole harness.it bogs out some times so i think its cause the harness. Besides that it runs fine.
Old 05-31-2019, 08:12 PM
JRCivic1's Avatar
Use the engine harness that came with your 1998 Civic... and move/modify/lengthen/shorten/add the necessary plugs and wiring to make it all connect to the EM1 B16A2 engine and drop it in. Get the needed plugs from the EM1 engine harness. Trying to make the EM1 engine harness work in the '98 Civic is a giant mess, so unless you are really good with wiring, I advise against this.
Old 06-01-2019, 09:56 AM
scottcraft's Avatar
That's good to know. I was going to take the entire engine harness and hondata from my em1 and engine and drop it into my 98. I guess I'll get both engines side by side and modify the d series harness.
Old 06-01-2019, 10:38 AM
Fish Twig
tony_2018's Avatar
p2t ecu and obd2a to obd2b conversion harness and a couple other things.
Old 06-02-2019, 05:07 AM
conor o h's Avatar
Thanks for the reply, what ECU must I use then? Would I have to get an Obd2a ecu from a b16 and would this plug into the ej6 harness?
Old 06-02-2019, 05:36 AM
Seagull Management
94EG8's Avatar
I'm guessing by the terminology that you're somewhere in western Europe. If you had an MPFI D-series you can modify the original engine harness and use that. If it was an SFI D-series you wont be able to. If you have the complete EM1 donor car you can swap the engine harness, cabin harness and door harnesses into the EJ6, you just can't use the engine harness by itself with the EJ6 cabin harness. Some of the immobilizers are easily bypassed, some aren't. The European stuff is often different than North American. If yours uses the red learning key I don't believe they are easily bypassed.
Old 06-02-2019, 06:01 AM
conor o h's Avatar
Thank you, yes my engine is mpfi d series, I'm not too sure what I need to modify on the d16 harness?, and would I also need an ecu from a OBDA b16 instead of the one from my Em1?
Old 06-23-2019, 01:54 PM
conor o h's Avatar
Right so I modified my d16y7 harness and plugged all in and no check engine light. I bought a p2t ecu from a b16A VTI. The engine starts fine but idles very low and idle fluctuates also. After you rev it the idle drops down very low and sometimes cuts out. The engine also lacks major power and bogs out when you accelerate, when you put your foot down theres hardly any change in speed it takes ages for it to pick up a bit of speed. I cleaned ith IACV but no change, what is causing this and how can I fix it? Could it have something to do with the ecu as the original p2t ecu that was with the engine came out of an obd2b car but the p2t ecu im using now is out of an obd2a car?
Old 06-23-2019, 02:22 PM
muellersfan's Avatar
Any CEL codes?
Have you checked the ignition timing?
Old 06-23-2019, 02:27 PM
conor o h's Avatar
Originally Posted by muellersfan
Any CEL codes?
Theres is no cel on and I can't find the obd2 plug anywhere, I'll check the timing tomorrow but engine ran fine before the swap?
Old 06-23-2019, 03:10 PM
Does the CEL work?
Old 06-24-2019, 04:23 AM
conor o h's Avatar
Does the CEL work?
Yeah was on before I wired vtec, wired the vtec and it turned off
Old 06-24-2019, 04:44 AM
Start with ignition system tune up and ignition timing. Then go from there.
Old 06-26-2019, 01:24 PM
conor o h's Avatar
I think I know the cause of this problem, the car was running on 2 cylinders as a result of bad injectors, I then went to change injectors and now the car wont start. Same thing happened yesterday when I unplugged a sensor when I plugged it back in it would not start again, so I left it and next morning started up fine. Now when i replaced the injectors same thing happeneing, I turn the key but fuel pump wont prime car does turn over, I checked the relay and grounds all good. I then went to inspect the ecu and found that when I had the ignition turned on and removed the small c plug from the ecu the pump would then prime? Seems very weird to me I i tried a different ecu and same thing was happening I have no idea what the problem is, any help I would graetly appreciate.
Old 06-28-2019, 08:07 AM
Fish Twig
tony_2018's Avatar
you have an electrical issue, inspect the engine harness.
Old 06-28-2019, 10:42 PM
conor o h's Avatar
Thanks for all the replys, the engine now starts I just plugged out the map sensor a couple of times and it started up, it's still misfiring tho the two middle pistons aren't getting fuel, changed injectors and they are both getting power, I suspect a signal issue how could I fix this?
Old 06-29-2019, 07:21 AM
This^ problem would have thrown the MAP sensor CEL code 3.
Ohm test those two injector ground wires.
Old 06-29-2019, 08:24 PM
JRCivic1's Avatar
Are the two middle fuel injectors plugged into the correct injector ???
Old 06-30-2019, 12:50 AM
conor o h's Avatar
Yes I think they are, I plugged injector plug 1 into the injector 2 and the cylinder fired so I presume it's plugs 2 and 3 are not getting signal?
Old 06-30-2019, 07:45 AM
conor o h's Avatar
I checked continuity all seems good, I changed ecu still no signal in 2 and 3, changed the injectors, checked for power I'm totally lost now?
Old 06-30-2019, 10:53 AM
Fish Twig
tony_2018's Avatar
please give details, being vague on your steps dont help much.
Old 06-30-2019, 02:23 PM
conor o h's Avatar
Basically I'm not getting any signal from the ecu to the injectors 2 and 3.I'm definitely getting power to all
the injector plugs, I swapped out the ecu for a different one but still no joy. I got a 12 volt bulb and wired the positive side to the positive wire on the injector plug and the negative side of the bulb into where the injector wire goes into the ecu and sends out the signal, I then cranked the engine and the the bulb lit up as it got a pulse from injectors 1 and 4 but not in injectors 2 and 3 so no pulse coming from the ecu, what could the problem be?
Old 07-02-2019, 07:02 PM
Fish Twig
tony_2018's Avatar
might want to double check your wiring again.
Diggie
K Series
08-09-2017 10:15 AM
HAMOTORSPORTS
Performance
02-18-2015 12:42 PM
GT500FTW
11-05-2012 09:57 AM
kanSiR
11-08-2007 08:02 AM
mrx
03-28-2005 05:56 AM
Quick Reply: B16 swap Loom and Ecu setup
