engine problem after valve clearance adj.
Old 05-23-2019, 11:34 PM
Default engine problem after valve clearance adj.
Hello..
the valve clearance was too loose and some noise. So that , I have adjusted the clearance with spec. the engine stall when cold and first start. are there any related with valve clearance? for now, I need press little throttle for the first start for a min.
anybody can give me some advise?
Brembomaster is offline
Old 05-24-2019, 01:22 AM
tony_2018's Avatar
Default Re: engine problem after valve clearance adj.
hot engine valve adjustment? cold engine valve adjustment?
tony_2018 is offline
Old 05-24-2019, 01:24 AM
that is cold engine adjustment.
I set the clearance in the middle of the range. So. I think it will not too tight and too loose.
Old 05-24-2019, 04:48 AM
muellersfan's Avatar
Are you saying the cold idle speed is set too low?
Does the engine run and idle fine after engine is warmed up?
muellersfan is offline
Old 05-26-2019, 07:07 PM
NO.. i am talking about the valve train clearance.
the the idle is fine after engine warn up.
Before I did the adjustment, the idle is good when cold start. after i did the adjustment, i need to keep little throttle open until to engine warm.
Thanks for your help ^^
Old 05-26-2019, 07:51 PM
What car and engine?
Have you tried cleaning the IACV?
Any CEL codes?
  • Ask a Question
Question Title:
Description:
