97 CIVIC B18B CRANK BUT NO START
Old 05-08-2019, 06:39 PM
DaCalviOne's Avatar
Default 97 CIVIC B18B CRANK BUT NO START
Hey guys I've had these problems so many times I dont have the time to anger myself with this one again so I'm looking for some help! I have a 97 civic with a b18b in it, have had it for a while no and Sunday when i went to start it it gave a crank but no start! I've never had this issue with THIS car before so i looked into a few options firstly. I also noticed the clicks from the fuel pump and relay were not there. changed the main relay and still no clicks. today I changed the fuel pump and still nothing. I had a walbaro in previously and replaced it with a new basic market one because I wasnt sure if the walbaro was used before purchase. anyone have this problem also or any opinions? please share!
DaCalviOne is offline
Old 05-08-2019, 06:43 PM
muellersfan's Avatar
Default Re: 97 CIVIC B18B CRANK BUT NO START
Check fuses 13 and 44. One may be blown.
Clean and tighten the G101 thermostat housing ground.
Then go from there.
muellersfan is offline
Old 05-09-2019, 01:36 PM
DaCalviOne's Avatar
changed both fuses and still nothing. Tested the power to most and the battery. no power is being brought to the fuel pump at all. The CEL comes on and stays the whole time. having a hard time finding the g101. anyone got a easier way to mark it out?
Old 05-09-2019, 03:24 PM
Right in the middle of your photo above... the 10mm bolt head through the pinched grounds of the engine harness attached to the thermostat housing just below the fuel feed line.
JRCivic1 is offline
Old 05-09-2019, 03:29 PM
DaCalviOne's Avatar
took it off and nothing
Old 05-09-2019, 03:42 PM
Make sure that the thermostat bolts are tight. Then clean the aluminum of the thermostat housing and scrape the ground contact surfaces shiny... then re install the 10mm bolt and tighten to spec. Make sure that the heavy transmission ground between the trans case and the right frame rail is clean and tight as well... and if all this is good, and you still have issues, you have another problem. Maybe a bad ECU, bad main relay or bad key switch.
JRCivic1 is offline
Old 05-09-2019, 03:59 PM
DaCalviOne's Avatar
Ok weather wasnt going to hold up today so I'll try that tommorow. Ive already replaced the main relay. I had this problem before with a b series hatch but I dont remember for sure but I think it would work then not work but it was the ECU so I hope its along those lines.
Old 05-12-2019, 07:43 AM
JuicedUpRice's Avatar
I would look into the ignition switch since you say the fuel pump is not priming and main relay doesn't click..
you can use this thread to try to diagnose the ignition switch https://honda-tech.com/forums/tech-m...agram-2926002/
JuicedUpRice is offline
Old 05-23-2019, 04:58 AM
DaCalviOne's Avatar
UPDATE: got a p75 ecu and it started! took a couple times but it runs on pretty low idle. use to sit at. 1 perfectly and sound great. now sounds rough and boggy. The ECU before was p28 before I switched. any ideas?
  • Ask a Question
Question Title:
Description:
