96 lx b20 power steering questions
I’ve spent the last two hours reading different forms. I know I need the p7j bracket to keep my ac. But what brackets do I need to keep my factory ps pump. If I can’t what brackets and pump do I need to use. Thanks if you have a link to a good write up I’ll gladly read it. Also can I keep my factory lines or will I need ls or crv ps lines
Re: 96 lx b20 power steering questions
Use the 3 bolt aluminum '97-01 CRV power steering bracket. Your '96-00 Civic SOHC P/S pump will bolt directly to it. In my experience, no contact between the valve cover and the P/S line has existed, but if it does, you can simply GENTLY bend the hard line portion of the P/S line to create the necessary clearance. Once installed, the engine and the P/S pump move together... so no more than 1/4" of space is necessary.
