Help needed
Help needed
I am having an issue with my #1 cylinder missing after the car is warm, I get no codes for it but sometimes car goes into limp mode with a solid check engine light with the jumper jumped to read codes, turn the car off and turn it back on and it’s no longer in limp mode. Car has new timing belt, head gasket, spark plugs, distributor, and rotor in the distributor.
Re: Help needed
Car? stock? mods?
What makes you believe cyl #1 is missing?
Code zero indicates the ECU has a power or ground issue or is bad.
Re: Help needed
Car is stock. I can pull injector plug or spark plug wire and it doesn’t change the way it runs. I don’t really know what ground to check other than possible battery ground. Trans ground looks to have never been taken off, and valve cover ground is fine.
Re: Help needed
Battery isn’t correct battery, I did pull the ground cable off when I was putting the stock head back on(someone had tried the mini me swap with a z6 head and I felt It was better to stay stock at first) and have had this issue since.
Re: Help needed
Do a compression check. and check the Injector on that cylinder. If there is no change when you take off the spark plug wire and its firing, then its either your compression or fuel on that cylinder.
Re: Help needed
The injector is good. Still the same even when I swap the injector. But only when car is when when it does it which is what baffles me.
Re: Help needed
Check your valve adjustment. That cylinder could be slightly too tight and when cold function properly, but when the engine warms up, the materials grow and can push the valve open slightly losing compression in that cylinder creating the miss that you have described here.
Re: Help needed
Check whether Cyl 1 spark plug has bright white spark when the engine misfires.
An intermittent poor connection in a wire harness connector affecting power or ground to the ECU would also throw code 0.
Re: Help needed
96Formula6spd
03-04-2011 08:58 PM
slowej1
09-25-2008 07:26 PM
Coolcat55
10
05-18-2007 07:36 PM
hans stoner
10-05-2006 08:15 PM
