trans swap for taller overdrive 2000 Civic Si
Old 05-15-2019, 09:38 AM
Icon5 trans swap for taller overdrive 2000 Civic Si
Hi all - I would like to know if there is a transmission that will fit in my 2000 Civic Si, B16, 5 speed that has a taller overdrive (meaning lower numerical gear ratio - higher car speed at same rpm)? Was told an Acura trans is like this, but have not run across any charts, etc. giving this information - any input?
cody61 is offline
Old 05-15-2019, 09:57 AM
Default Re: trans swap for taller overdrive 2000 Civic Si
Install an LS 5th gear from a 92-01 Integra LS trans.
chuck chainz is offline
Old 05-15-2019, 11:41 AM
rickkane's Avatar
This ^^
rickkane is offline
Old 05-15-2019, 07:30 PM
Yes, the '04-01 Integra LS 5th gear set is a drop in swap inside the S4C ('99-00 Civic Si) transmission. It will drop the engine speed by 1000 RPM at 80 mph.
JRCivic1 is offline
Old 05-15-2019, 07:32 PM
Moderator
TheShodan's Avatar
and through the entire engine's torque multiplier out the window. I did this 5th gear change on my EM1 and instantly regretted it. use a GSR 5th instead.
If you're interested in the thread I gave feedback on this change the year I performed this abomination, leu me know
TheShodan is offline
Old 05-15-2019, 07:41 PM
The standard B16A2 has no torque... so I could see how this could be an issue. The GSR 5th gear set could be a good compromise between the stock 5th gear pair and the LS 5th gear pair... or just add a bunch more displacement or HP and the tall LS 5th gear pair will work just fine.
JRCivic1 is offline
Old 05-16-2019, 06:47 AM
Moderator
TheShodan's Avatar
I hear you.. Even with my G"LS"R build that 5th great was useless even on the highway, and the GS-R 5th was a better overall use, I still wouldn't use it.
Torque multiplyer concept is still applied even in the torqueless wonder B16A2. But going into that takes this thread off course.
Old 05-16-2019, 06:48 AM
tony_2018's Avatar
I recall someone changing out the final drive on the b16 with a LS.
tony_2018 is offline
Old 05-16-2019, 07:40 AM
chrysler kid's Avatar
I want to say I'm still getting 29mpg in my si. If it was 24 or something I could reason a swap. But the si just drives like a motor cycle
chrysler kid is offline
Old 05-16-2019, 08:18 AM
DaX
DaX's Avatar
Yeah, swapping in a different 5th has never appealed to me either. I've got a (single cam) Si transmission in my EF Sedan and still get about 30 mpg every tank, and the high RPMs don't really bother me...just crank up the music, haha.
DaX is online now
Old 05-16-2019, 08:20 AM
tony_2018's Avatar
That sounds about right in the real world. I was gettin somewhere near that with a b20 utilizing the b16 transmission.
Old 05-21-2019, 08:47 AM
Hey, thanks for input. Went with a little bit taller tires, made a nice change to audible taching out factor, but was noticeable how it did kill off the bottom end. The car seems to love churning away at 4000 rpm, I just get tired of listening to it. Less invasive than swapping gears or trans, cool you guys know how to do that - thanks - Cody
cody61 is offline
Old 05-21-2019, 09:07 AM
Also, I am new to this website - I put an add in the classified section, but it is not there today. It might have been taken down because I did not have a card with the required info in the photos with the cars, not sure. Any input? seemed like they posted no problem. A guy welcomed me as a new member, seemed to be the web sight guy, now I can't figure out how to contact him.
cody61 is offline
Old 05-21-2019, 05:36 PM
Moderator
TheShodan's Avatar
you must follow those guidelines in yellow highlights at the top of the forum. those without that info are automatically taken down
  • Ask a Question
Question Title:
Description:
