Camber in a 95 coupe
Hey Guys,
I知 running a 95 civic coupe on dirt and I知 looking to change the camber without using a camber kit. Is heat and bending the preferred method or would I be better off to drill the holes out? I知 thinking the heating method would weaken it in the case of an impact. Any thoughts?
Re: Camber in a 95 coupe
I'm not even sure what "on dirt" means
EBay for cheap camber kits.
Technically the 92-98 cars ran so much positive rear camber you shouldnt need a camber kit of you have a conventional lowered setup.
I have a hunch you are going to **** up the car and run a stance boi setup
Oh ok makes more sense now. So can you run an adjustable upper ball joint on the front? And yes you would want to heat up and bend the upper rear control arm to give you some negative rear camber
b18LS
Suspension & Brakes
04-18-2007 06:05 AM
