pulled engine - now cel - don't know what to do
Old 04-29-2019, 02:51 PM
93DelslowSI's Avatar
Default pulled engine - now cel - don't know what to do
Hello and thank you to anyone willing to try and help. Basically i pulled the engine on my 93 del sol and did some work to it about a year ago. Got the engine back in the car, hooked everything up and it had a solid CEL, but it was still running pretty decent for a while! Anyways, one day i go out to try and mess around with the tune on it and the fuel pump wouldn't prime. I've checked everything from swapping ecu, fuel pump, fuel relay, checked ALL grounds. I really don't really know what else to do other than take her to the damn scrapyard at this point. This is my first project car and iv'e spent so much time working on it, I would really love to be able to just pull it out of the driveway and drive it for once. Thanks again!
93DelslowSI is offline
Old 04-30-2019, 08:53 AM
Default Re: pulled engine - now cel - don't know what to do
What was the CEL code? That might be start
civichxtreme2 is offline
Old 05-01-2019, 06:07 AM
FIXED!! Power wire to fuel pump was cut and not making proper connection
Old 05-01-2019, 07:43 PM
Removing and re-installing the engine doesn't get anywhere near the fuel pump wiring... how did that get cut ???
JRCivic1 is offline
Old 05-02-2019, 05:11 AM
Scorned Ex ?
Old 05-03-2019, 04:20 AM
tony_2018's Avatar
Pulling an engine will def cause a cel because there are sensors that the ecu is not seeing, engine out of the car.
tony_2018 is offline
Old 05-03-2019, 11:42 AM
O.G. triple O.G.
NVturbo's Avatar
incompetent install of the fuel pump likely. Yeah, I'm betting that's the case here.
NVturbo is offline
  • Ask a Question
Question Title:
Description:
