Need help with B18c1 swap into 1997 civic dx hatch - no b/s answer
hey im new to this forum. i am wondering for a 1997 civic dx hatch back i am installing a 1998 b18c1gsr engine and trans the two part dc engine harness doesnt work in an ej and the dx harness is obviously lacking quite a bit ! my most likely pick is going to be an engine harness from an obd II a civic ex , or possibly less likely one from a 99-00 si , also running a p73 obd I ecm with hondata so the second o2 sensor is gone and any other emissions related miss haps and the iabs from the gsr intake manifold will be inert then endyn custom skunk mani goes on ! not looking for i think this might work or a buddy of mine did this but he had to cut splice solder and do all kinds of junk looking for cold hard facts lemme know. any good info would be appreciated thanks
Last edited by Former User; 12-08-2010 at 09:49 AM. Reason: Deleted off topic inflammatory comments
Re: no b/s answer
i will be nice ! i'm sorry if i have ofended anyone here
Last edited by Former User; 12-08-2010 at 09:46 AM. Reason: Off topic comments deleted
Re: Need help with B18c1 swap into 1997 civic dx hatch - no b/s answer
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
Because you are a new member, I edited the title for you this time.
Also, keep all discussions here focused on tech. Otherwise, this thread will be closed.
Seagull Management
You can either use the original Civic harness and ad the wiring for vtec and IABs (you may need to wire knock, but generally if you're running a chipped ECU its disabled) or you can run a '96 - '98 EX harness (you'll still need to wire in the IABs though) No '99 - '00 Harness will work.
freddy chavez
01-19-2013 08:07 PM
YungICY
03-17-2012 02:56 AM
IHEARTMYHONDA91
03-14-2008 09:55 AM
