93 Del Sol/Gsr swap won't start!
I have a 93 del sol with a gsr just bought it from a friend was told it ran great he said one day he went out to start it and it will just pop! I asume it jumped time why? And i take it to time it just put the time gear arrows up and put cycinders 1 and three top center! right any info would help please let me know what u think!
Re: Gsr Del sol wont start!
Cylinder 1 & 4 at tdc. What is this pop at start up? Can you explain more details? Is it backfiring or nor not starting at all?
Re: 93 Del Sol/Gsr swap won't start!
Post clear pictures of the cam and crank positioned at TDC1.
You need to give more information. Does the fuel pump prime? Is there spark at the plugs? Any CEL codes?
check your spark .. how ?? take a sparkplug wire out and put a screwdriver inside
hold it next to a bolt on the valve cover it should throw a little spark which u could be able to see ... then check your fuel ... either hear if ur fuel pump primes ... or see if your hear the injectors or take them off ... thats how i would test it ... idk if other people have other methods
guitarma
09-26-2011 12:46 AM
